VEMS Bigger Map Sensor Bug?
Posted: Fri Mar 06, 2015 2:14 pm
Hi,
I replaced the internal 400 kPa map sensor by a 700kPa internal.
I changed the ECU calibration like VEMS Wiki tells -->
http://vems.hu/vt/help/v3/v3_ecu_calibration.html
700 : set "MAP range unit"> 510 and MAP range=778 kPa --> done ans sensor is working fine - tested up to 650kPa on VEMS Gauge
Problem, now I see all map values in VEMStune are half and Top Limit in Tables is 255
When I try to set bigger values than 255 in VE or Ignition table I get an error message --> "VEMS value is incorrect or out of range"
??? What is the issue - did I miss something??
regards
3.6 board, 1.2.10 firmware
update - when ECU is connected, all tables can be set up to 510kPa... but not more than 510kPA
When I log and save a logfile - all pressures are up to 510kPa in this logfile... ECU disconnected
But when I save a config file from the ECU, disconnect the ECU and load the config to VEMStune all MAP values are half in this file
regards
