Re: Casey's 200 20v: IT RUNS!!!WOOOO!!!!
Posted: Thu Aug 23, 2012 4:44 am
sounds mean, its going to sound evil with boostage.
WOMBAT wrote:Never mind what is still left to do. IT RUNS!!
groff wrote:WOMBAT wrote:Never mind what is still left to do. IT RUNS!!
seeeeeee, glad you finally adopted my mentality now!
WOMBAT wrote:My turbo oil feel leaks between the center section and the brass NPT adapter.
Teflon tape or crush washers?
WOMBAT wrote:death 4kqt wrote:sounds mean, its going to sound evil with boostage.[/quote]
Hell yes it will!
Did you use the stainless steel universal coolant hoses on your car? If so, are they worth it?[/quote]
I used it, and it works, but i don't really like it. I don't really have any choice without some major reworking, so that is why I used it. It has served its purpose, so i guess I am satisfied with it.
Posted: Thu Aug 23, 2012 10:09 amYea I might have to use them. The car has 1.25" I/O and the radiator has 1.5" and 1.75" I/O
Posted: Thu Aug 23, 2012 10:13 amlots of oem rad hoses have small flare/transitions on the ends
or another option
im making 1.25" mandrel alu water pipes for my 16vt 4kq, and using 1.25>1.0" reducer elbows off the block connections and 1.25" straight silicone hump hoses to connect to the b3 80 radiator
Posted: Thu Aug 23, 2012 10:13 amcan you have the outlets of the radiator reworked with sizes and locations that would allow stock type hoses? I always find myself wishing my car could run all stock hoses.
Posted: Thu Aug 23, 2012 6:30 pmI lucked out. Went to Advance Auto with some bent up coat hangers and a tape measure and ended up with some decent radiator hoses!
Before: only used the two larger hoses
After:
Installed:
Good to go!
Posted: Thu Aug 23, 2012 6:34 pmget some non perforated clamps on those!
Posted: Thu Aug 23, 2012 6:45 pmOh hush, you
Posted: Fri Aug 24, 2012 4:42 amneeds moar bling to be a show car!
Posted: Fri Aug 24, 2012 7:15 amHell yeah Casey! Nice stuff man.
Posted: Fri Aug 24, 2012 7:42 amI drove it a blistering 15mph this morning around my block! Never been so excited to drive so slow haha - it felt great! Also realized I hadn't filled my hydraulic system yet, oops.
Posted: Sat Aug 25, 2012 9:26 amFilled the hydro system and that's all well and good. It sounded like I had air in the ps pump but it turns out it was my distributor rattling... That can't be good for timing accuracy. Can dizzys be rebuilt?
Posted: Sat Aug 25, 2012 10:05 amyes, can be rebuilt
Posted: Sat Aug 25, 2012 11:26 amIs that a DIY item or send out for rebuild kind of thing
Posted: Sat Aug 25, 2012 11:36 amDepends on what version of the distributor you have and what parts you intend on replacing? Do you have a metal gear or stock plastic?
Posted: Sat Aug 25, 2012 12:01 pmMetal gear - not sure if it's a matter of shimming or if the bearings have play
Posted: Sat Aug 25, 2012 12:15 pmShims there are no bearings.
