Page 2 of 3
Re: Sebastian's 91 Coupe Quattro - 3b swap - Vems - e85
Posted: Tue Jan 20, 2015 11:00 pm
by Zaworek
Thank you im working to get this post going got another couple thousand photos to go thru
Posted: Tue Jan 20, 2015 11:03 pm
by Zaworek
Thank you, working to get this post up still have couple thousand photos to go thru and some vidoes
Posted: Tue Jan 20, 2015 11:15 pm
by Zaworek
engine bay prep for engine install adding some heat shield
Posted: Wed Jan 21, 2015 1:50 am
by alxdgr8
Looks great so far!
Posted: Wed Jan 21, 2015 11:19 am
by Zaworek
some more parts and work, custom bracket for the coil setup based on strut bar with welded mount for the coil rails
custom bracket for the rear bumper from Jack " Mayham project" ,
the fuel rail didnt fit on stock s2 intake manifold wih spacers so some grinding was needed to fit it perfectly
Posted: Wed Jan 21, 2015 11:26 am
by dana
sebastian! good to see you here man. I still have that 5x112 spare, im sure you found one already since I forgot about it months ago.
Looking awesome.
Posted: Wed Jan 21, 2015 2:14 pm
by Zaworek
Oil housing has been rebuild and some an fittings added
Posted: Wed Jan 21, 2015 2:19 pm
by Zaworek
distributor brass gear
Posted: Wed Jan 21, 2015 4:09 pm
by Zaworek
engine drop with hand of a friend Pit
Posted: Wed Jan 21, 2015 4:21 pm
by Zaworek
dropped
Posted: Wed Jan 21, 2015 4:28 pm
by Zaworek
some addition of spark and random photos
Posted: Wed Jan 21, 2015 4:37 pm
Keep em coming, awesome build!
Posted: Wed Jan 21, 2015 4:39 pm
by Zaworek
down pipe and radiator
Posted: Wed Jan 21, 2015 6:58 pm
by 83urquattro
Looks good seba.
Posted: Wed Jan 21, 2015 11:03 pm
by Zaworek
here is one for you Adam Thanks or the paint job
Posted: Thu Jan 22, 2015 5:09 pm
by Zaworek
here some random shoots i found in my folders
coupe being pressure tested for any leaks from brake fuild, coolant, clutch etc,
catch can loction
Dear Peter cleaning the whole windshield from over spray with small razor
Posted: Thu Jan 22, 2015 5:44 pm
by Zaworek
random under shoots
Posted: Thu Jan 22, 2015 5:57 pm
by Zaworek
rear strut brace in place
oil cooler installed
front support installed along with upgraded hid head lights and s2 bumper covering an s2 IC
Posted: Sat Jan 24, 2015 4:36 pm
by Zaworek
A person randomly started talking to me at local parking about my coupe, he said that he also owned a coupe while ago and he missed it so much since he sold it. The only thing left he had was his car magazine that kept his memories alive. He asked me for my information he wanted to give me somethink.
and here it is a bit of history
Posted: Sat Jan 24, 2015 4:38 pm
by Zaworek
here is the personal note from him
Posted: Sat Jan 24, 2015 4:51 pm
by Zaworek
coupe is ready for Marc
Posted: Sat Jan 24, 2015 9:59 pm
by Zaworek
Posted: Sun Jan 25, 2015 11:55 am
by Zaworek
on the way to Marc at EFI Express after getting alignment done
here are some dyno pull and launch control videos
dyno pull 8200 rpm's
http://youtu.be/Gve438Dnjt4launch control
Posted: Sun Jan 25, 2015 12:04 pm
by Zaworek
[youtube]http://youtu.be/Gve438Dnjt4[/youtube]
Posted: Sun Mar 15, 2015 9:57 pm
by Zaworek
Finally i was able to find some time to take her out to see some snow
