I decided I'm not happy with my avant, so I'm selling it. 180,xxx miles, daily driven.
Mods:
-2Bennett front 4-piston brake kit
-RS2 Chip, exhaust manifold, 034 replica injectors, MAF
-Euro lights
-H&R lowering springs with Bilstein shocks
-AEM wideband (needs rewired for the power, currently interferes with the stereo)
-Silicone boost hoses
-3 inch ghetto exhaust (sounds good, looks bad)
Recent Maintenance
-both front lower control arms, both front outer tie rod ends and alignment
-thermostat
-mc1 flywheel, clutch, throwout bearing and fork (old TOB grenaded, took out the timing pin on the 3B flywheel)
-clutch master
-both knock sensors
-spark plugs
-4 tires
-front pads, rotors turned
-rear pads and new rotors
-new NAPA battery
-ignition switch
The bad:
-Currently chasing a goofy misfire, only under 12(ish)+ psi boost and only when warmed up
-few rust spots
-clear peeling on the sunroof
-suspension squeak in left front
-coolant leak
I'm working on fixing the misfire issue, suspension noise and coolant leak. I intend to have this stuff fixed for whoever buys it, but if we can reach a reasonable as-is price, I'll let her go. I'm hoping to sell quickly because I have my eye on a car, and I need to pay off my bike to get a loan on the car. Asking $4500 OBO if I get those issues fixed. email me at gtrn116 at gmail dot com or text me at 614 6three4 three777 with offers or questions.
1991 Indigo Mica 200 20v Avant
Re: 1991 Indigo Mica 200 20v Avant
Sent from my SCH-I545 using Tapatalk
Bump. $4000 as-is?
Check your fuel injectors on the misfire. My saab did the same thing.
Wish you were closer.
I don't want to part it out, but if I have to, I will...
