bad motronic 2.3.2 ECU wanted
m looking for bad motronc 2.3.2 ECU's. im working on creating full ECU schematics and mapping out all of the hardware inside and i need bad ECU's to remove all of the components off of the PCB's so i can get nice clear images and use them for tracing everything out. once this leg of the work is done than the schematics could be used to repair ECU's or reverse engineer them and their software for tuning. as with all of my findings and research in the past i promise to publically post all the information for everyone to use!
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
