AAN/3B ECU with GM 3 bar map sensor
anyone here ever see or attempt to use a GM 3 BAR MAP sensor in place of the factory bosch unit? just curious before i attempt this one if its going to be worth my time. i know i'll have to mount it externally which isnt a problem. seems like a far cheaper alternative than buying an OEM bosch 3 BAR map or the 034 MAP sensor.
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
Re: AAN/3B ECU with GM 3 bar map sensor
