bracket location for cps
Posted: Sat Jan 11, 2014 1:26 am
by varia
I just got my 3B head from the machine shop.
I got hallsender billet bits to hold the cps
I want to install it, but i need to know the exact location and I also have acces to AAN head.
But im looking for wisdom, how would you guys measure it?
I found this on s2forum, but i dont want to remove the cam shaft.
http://www.s2forum.com/forum/showthread ... its&page=2
So, how would you measure it? Any ideas?
Thank you
Chris
Re: bracket location for cps
Posted: Sat Jan 11, 2014 2:33 pm
by scubadave
I had similar thoughts if I had to do the same. I was just going to make a bracket that bolted to the head in a few different locations on both intake and exhaust sides that wrapped around bolting to the cps location to make it hold it exactly where it is supposed to be to weld it in place. dont know how it would play out, but it seemed like a good idea.
Posted: Mon Jan 13, 2014 7:29 pm
by varia
Thank you Dave
AAN head with original bracket
Made a template from sheet metal
Intalled the bracket onto the template with 1 bolt and the mid pin
JB weld on the other side till its TIG welded
Came out perfect, enough clearance all around.
Thx
Chris
Posted: Mon Jan 13, 2014 8:01 pm
by scubadave
you're very welcome. glad it worked as well as I had envisioned. Now I know it can be done quite easily if I need to convert a 7A head. I also figured the same with a template for drilling the water manifold.
