Type 44 brake upgrades?
gtn116
Post by gtn116 »
What is the cheapest brake upgrade available for the type 44 cars? I have G60 fronts OR UFO at my disposal. Also, any suggestions for the rear too. I have to do pads and rotors, I figure might as well upgrade while I need it.
yodasfro
Re: Type 44 brake upgrades?
Post by yodasfro »
If the UFO's are in working condition that would be the best/cheapest choice. Everything else will require bigger wheels and more $$$. When the UFO's stop working you can convert the upright accept the HP2's or touareg/cayenne 4 and 6 pots. Just note you will need V8Q/200 20v front control arms with the 19mm ball joint.
gtn116
Post by gtn116 »
How do I go about modifying the upright? And which rotor would I use with each upgrade?
yodasfro
Post by yodasfro »
Justin517
Post by Justin517 »
yodasfro wrote:If the UFO's are in working condition that would be the best/cheapest choice. Everything else will require bigger wheels and more $$$. When the UFO's stop working you can convert the upright accept the HP2's or touareg/cayenne 4 and 6 pots. Just note you will need V8Q/200 20v front control arms with the 19mm ball joint.
Tourareg 4 and 6 pistons have the same bolt spacing and offset as HP2's?
quattro
Post by quattro »
I just fitted urs6 struts with hp2 calipers in mine and the vented rears aswell
yodasfro
Post by yodasfro »
Justin517 wrote: Tourareg 4 and 6 pistons have the same bolt spacing and offset as HP2's?
Yes same bolt spacing as the HP2's so they can be bolted to the UFO housing's just the same as doing the HP2 swap not sure on the exact rotor I believe it's from a Merc but the hub bore needs to be opened up a little. http://www.audizine.com/forum/showthrea ... &styleid=8
http://forums.quattroworld.com/allroad/msgs/68518.phtml
Justin517
Post by Justin517 »
Very cool, thanks!
too bad I won't be able to run 15's with them, oh well... maybe some UrS Fuchs... or 16" mesh style reps.
