RS2 bracket bolts
Posted: Tue Jun 18, 2013 8:10 am
by Zerb
anyone know where to source these pieces of gold? RS2 brackets to boxster s calipers.
12 x 1.5 x 25mm for the bracket to the strut
12 x 1.5 x 62mm for the bracket to the caliper
McMaster Carr aint got shit in that thread pitch. :wave:
Re: RS2 bracket bolts
Posted: Tue Jun 18, 2013 11:31 am
by 20VAvant
Fastenal.
http://www.fastenal.com/web/products/de ... rfqLineId=
Odd sizes like 62mm are hard to find unless you buy Audi Factory for $$
Here is a 65mm and take it to a sander.
These are HHCS (Hex Head Cap Screws) however, If you are looking for SHCS (Socket Head Cap Screws) I can't find much either.
Best of Luck! :thumbsup:
Posted: Tue Jun 18, 2013 12:00 pm
by Zerb
ya, the shorter bolts those will work. the issue is the longer bolts that hold the caliper to the bracket NEED to be socket heads from what i can tell. you may be able to get away with a flanged head, but im not sure.
Posted: Tue Jun 18, 2013 1:23 pm
by Wheeljack
After looking around unsuccessfully (McMaster, local Fastenal dealer, etc.), I ended up just getting the SHCS's (caliper to bracket) from the Porsche dealer. For the other bolts (bracket to knuckle), I just trimmed down my original caliper carrier bolts. There is not enough room for anything else as the counterbore was sized for the smaller head of the SHCS.
Since I was only buying two pair (less than $20 IIRC) it didn't take long at all to spend the difference in cost in my time looking for a cheaper source. Of course they needed to order them in as well.
Posted: Thu Sep 12, 2013 3:33 pm
by Zerb
for anyone interested the porsche part number on these is 999-073-402-01, pelican parts had them in stock for $5 a bolt. done and done.
Posted: Mon Sep 16, 2013 12:42 pm
by Zerb
so, how does everyone feel about these bolts. they are the part number listed above that i looked up to fit a stock porsche 996 body style with the calipers i have...boxster S.
i see that apikol has 2 different sets listed, this is the longer, 72mm version, of those sets. i dont see what it could interfere with, then again i havent had them on the car just yet.
Posted: Mon Sep 16, 2013 6:20 pm
by SEStone
The OEM Porsche application has those bolts going into the aluminum wheel bearing housing, which is probably much thicker than the steel bracket. You probably want RS2-length bolts, which use that thinner bracket.
Sam
Posted: Mon Sep 16, 2013 6:25 pm
by Zerb
Bolted up to the car they have no interference with anything. I guess I'm just not seeing, or understanding, the issue with using these longer bolts.
Posted: Mon Sep 16, 2013 6:27 pm
by my2000apb
