Audi 4000q 2.7 Single Turbo
Posted: Sat Jun 19, 2021 10:20 pm
I JUST CAN'T STAY DORMANT WITHOUT A BUILD!
Picked up a 4000q with the intention of 5.2 swapping it as I have everything short of a flywheel and headers to make it happen again. Welp, guess I should've measured first! I know the 2.7t inside and out and I know they're pretty potent as well as the aftermarket support is through the roof, so... without further rambling...
I put the V10-Swagon to good use with a nice 5-hour trip and picked up a well maintained, recently resealed 2.7t. Met some dude off the parkway and was able to fit the engine hoist aswell to unload/load from his truck! Plan, for now, is a nice passenger side mounted single turbo setup with log style manifolds. This will be a budget build just to keep me occupied... Frame rail engine mounts were cut out as I'll be welding in 1/4" plates that'll be threaded. From there I can make a removable engine mount bracket to keep everything tidy, yet strong.
I'm thinking 400~ wheel with insane spool in a 2800lbs car with 195's should be saucy.
20210620_153657 by Joel Francisco
20210620_203522 by Joel Francisco
20210620_181945 by Joel Francisco
20210628_174816 by Joel Francisco
20210623_182207 by Joel Francisco
20210623_182155 by Joel Francisco
