Similar to the 13pc Facelift (FL) trim except it doesn't have the radio surround or the rear seat heater control panel. It will all work on a SWB facelift car though. I was planning on running it on my FL S8 and then wrapping the radio and rear seat heat panels in matte black vinyl. I had most of it mounted in the car already when I found a FL set. The PFL front ash tray cover is slightly different (raised carbon lip vs machine aluminum lip) but it is still the same size and works on a FL car. The cup holder cover button is also black on the PFL versus silver on the FL. I believe the rear door trim pieces fit only a SWB car only, but I haven't ever measure an A8L to confirm.
This set is in great shape overall. A few pieces like the arm rest trim have some hazy parts in the clear coat where the rubber gasket sits. The front driver's side door trim has 3 small hairline cracks in the clearcoat that I've tried to take pictures of and are hardly noticeable unless you look closely. One of the rear door trim pieces also has a defect in the corner that is pictured. Parking brake handle trim piece 'fork' is NOT broken surprisingly. Shifter surround doesn't have the plastic piece that attaches it to the center console so you'll need to transfer that from your wood trim.
OE factory pieces
Left Hand Drive
Automatic shifter surround (but can work with a manual swap; I made this work for my FL trim set and 6MT swap)
SOLD
Message me for shipping quotes.
Pickup available in Seattle
IMG_20200716_192545 by Vex Art Media, on Flickr
IMG_20200716_192805_1 by Vex Art Media, on Flickr
IMG_20200716_192813 by Vex Art Media, on Flickr
IMG_20200716_192802 by Vex Art Media, on Flickr
IMG_20200716_192759 by Vex Art Media, on Flickr
IMG_20200716_192735 by Vex Art Media, on Flickr
IMG_20200716_192713 by Vex Art Media, on Flickr
IMG_20200716_192706 by Vex Art Media, on Flickr
IMG_20200716_192704 by Vex Art Media, on Flickr
IMG_20200716_192659 by Vex Art Media, on Flickr
IMG_20200716_192654 by Vex Art Media, on Flickr
IMG_20200716_192636 by Vex Art Media, on Flickr
IMG_20200716_192649 by Vex Art Media, on Flickr
IMG_20200716_192628 by Vex Art Media, on Flickr
IMG_20200716_192615 by Vex Art Media, on Flickr
IMG_20200716_192622 by Vex Art Media, on Flickr
IMG_20200716_192550 by Vex Art Media, on Flickr
IMG_20200716_192915 by Vex Art Media, on Flickr
IMG_20200716_192910 by Vex Art Media, on Flickr
IMG_20200716_201229 by Vex Art Media, on Flickr
