UFO to HP2 conversion 200 20v
Posted: Wed Oct 02, 2019 7:48 pm
Been talking about conversion to HP2 set-up for quite some time (this and the last 200 20v!) and time is now. Have a hub bearing that's making some noise... The UFO's are thin, and started to thump on 1500 mile trip this last summer! Have always been happy with UFO braking performance, but they are almost unobtanium and where available, stupid expensive....not happening. Picking up pair of HP2's from a local shop for $150 , will reseal and clean them up...
Could go the G60 route, (USR6 housings) but that would end up with less brake than the UFO's!
Plan is to turn hub down at work when apart for bearing, drill mounting holes to 14mm and take off the unused mount hole. Have read all the posts i could find over the last year or so as regards this conversion but still a few questions!
1. When shopping around for the HP2 rotors I'm seeing 320 and 321 mm. OEM EPC lists both, normal jobber source also listing both sizes. Is there any difference? (besides the 1mm larger dimension) Leaning towards Zimmermanns.
2. Last, but not least.... Currently have Fuchs. I've queried several times with only Yoda replying. Any first hand knowledge with HP2's and Fuchs URS6 16's? Found something way back when, somewhere, somehow, that they would fit! But if i do all this and these wheels with good tires don't fit I'm kind of screwed!!!! // Yoda thinks may need 5mm spacers, but others have claimed they will fit?//
This car is no longer my daily, but like to drive on longer road trips, etc. Want to do this right!
Posted elsewhere, and got a little info. Believe the 321's are what i want! Got a reply that rotor may not center properly on the UFO as the centering portion is a little shallower on the UFO hub. He used the G60 hubs instead. My concern with G60 hubs is slightly different offset between that and the UFO hub!
Any BTDT would be greatly appreciated!!!!!
Eric
Eric
