x5 850cc ev14 injectors + modified fuel rail/FPR
have 5 850cc ev14 injectors plus an AAN fuel rail modified to pull the fuel rail closer to the intake manifold so the injector are super snug.
Also will include ev14 to the normal injector plug adapters
$200
Re: x5 850cc ev14 injectors + modified fuel rail/FPR
What brand are the injectors? Do you have any of the original info sheets for them?
Bosch injectors
No original info off hand. They were from Ebay from what I recall.
Post by alxdgr8 »
Do you have a picture of the rail on the car? Curious if this might work for my MTM reverse intake (similar to wagner).
Sent from my Pixel 3 XL using Tapatalk
alxdgr8 wrote:Do you have a picture of the rail on the car? Curious if this might work for my MTM reverse intake (similar to wagner).
I do not.
The modification was just cutting the tabs with the holes for the bolts, and moving them slightly down and welding them back on.
bumparoo
Stiiiiiiiiiiiiiiiill gotem.
