PARTOUT: 1993 Audi urs4//UPDATED LIST & EVERYTHING IS OBO!!!
I’m parting out a 1993 Audi urs4.
The car has around 175k miles. It’s
pearl white on ecru interior. Every
single piece is for sale. I have a spare
AAN longblock for sale. I have a 7a
shortblock. Also have 2 5 speed 01e’s
and 3 locking early c4 & c3 rear diffs.
Everything worked as it should for
the most part. Windows, wipers,
accessories, radio, transmission,
rear diff, mirrors, sunroof, seat motors
seat heaters, ice cold a/c.
Payment will be through PayPal. For
goods & services payments add %4
to the total. Buyer pays shipping unless
stated otherwise. Local pickup is preferred
but have no issues shipping items big
or small. Deals can be made and will
be given if multiple items bought at
the same time.
I have a lot going on at the moment
so I’m telling everyone that on small
items going through usps you have to
give me 3-7 days to ship those out. On
very large freight shipments I will need
2-4 week lead time. I recently started my
own shop and have my own projects
going on on top of 2 partouts at the
same time.
Aftermarket parts:
4. Custom fmic kit—$500 shipped
Universal 2.5” piping & silicone coupler
from summit. Cx racing intercooler
18x12x3. This kit is setup for cars
using stock or rs2 style manifolds.
Also will only support 300-400whp.
Throwing in another charge piping
kit for free. I’ve been holding onto
it forever.
6. Driver a/c vent gauge pod with AEM
digital wideband AFR gauge—$120 shipped
7. 2bennett camber plate with factory upper perch- $300 shipped
8. H&R green front lowering springs— $150 shipped
Stock parts:
3. AAN timing cover set—3 pieces-$150 shipped
outer with no cracks, inner with good clips, lower metal cover
Will include hardware
4. AAN throttle body—$100 shipped
Working TPS,
5. AAN brand new belt tensioner—$100 shipped
The new one appears to be an
aftermarket unit. No vw/Audi stamp
will include a brand new contitech belt
B. factory tensioner with a noisy bearing.
Makes a little noise. Will also include
new serpentine belt—-$100 shipped
7. Injector cover—$75 shipped
8. Stock injector set—$100 shipped
I have 2 sets//cleaned & tested
9. AAN fuel rails with FPR & braided
lines ( have 2) early banjo feed—$100 shipped
Will include good fuel filters
10. AAN water manifold—$65 shipped
I have two
11. Mint urS airbox—$125 shipped
all clips intact, will come with a
new Mann filter and a used K&N
drop in filter. Also both air snorkels.
2nd one with only a new Mann filter.
Identical setup.
12. 2 AAN mafs with screens cut out—$65 shipped
They both function properly
B. One unmolested MAF—$100 shipped
13. Stock AAN exhaust manifolds—$65 shipped
Have 2
14. Stock AAN wastegates—$115 shipped
I have one left with flex pipe
15. urS metal smic & crossover pipe—$200 shipped
Will include the shrouds. I have 2 sets
16. urS power steering pump—$250 shipped
Rebuilt ZF unit serial number appears
to say rebuilt in 2013
19. urS starter—$50 shipped
20. urS alternator—$100 shipped
21. urS a/c compressor—$100 shipped
works. Car had ice cold A/C
22. urS steel accessory brackets—$125 shipped
Power steering & alternator/compressor
bracket
23. urS g60 front uprights—$300 shipped
Mint set
25. Strut mount covers—$30 shipped
28. mint urS front grill—$125 shipped
I have 3–one has a good badge,
one has a faded badge, and one
has no badge.
31. Front bumper grill set—$140 shipped
All 3 intact pieces
32. Amber corner markers—$65 shipped
3 sets will include bulb sockets, bulbs,
and wiring pigtails
33. urs4 hood—$100 picked up or $100 + shipping
34. urs4 full size side mirrors with —$150 shipped
Working motors glass sold
35. urs4 doors—$250 shipped per door or
$800 shipped for 4 doors—I have 3 sets
of 4// 2 faded black and one pearl white
36. urs4 windows—$100 + shipping per window
or $400 shipped for all 4
37. Stock delta radio but needs code—$75 shipped
38. Ecru interior bits—offers???
39. Factory boost hose sets—$100 shipped
3 hoses— throttle body hose, Michelin
man hose, and turbo outlet hose
40. Factory AAN coil cover with coilpacks
some packs are no good—$120 shipped
Includes POS & bracket
41. Near mint inner tail lights—$300 shipped
Includes bulbs, bulb holders, & wiring
pigtails driver has faded reverse light
43. Good instrument cluster with working
lcd screen and all gauges & lights—$250 shipped
two with bad lcd’s but the rest working—$100 shipped
44. x2 early 5 speed 01E trannys—$500 shipped a piece
Good working condition
45. x3 locking rear diffs—$350 shipped a piece
46. Carbon fiber interior trim set
with black climate control and
ashtray pieces. Most of the carbon
has cracks in the clear— $150 shipped
47. 3 sets of 4 working window motors—$125 shipped
All factory and tested & verified working via switch
48. 2-3 sets of 4 working window regulators—$125 shipped
49. Mint mid & lower door/fender moulding set—$300 shipped
50. urS sedan outer tail light sets
will come with bulbs, bulb holders,
brackets, hardware, and wiring pigtails —$125 shipped
I have 2 sets
53. Stock speaker & amp set—$125 shipped
54. urS complete shift linkage set—$150 shipped
1 set left
55. urS factory GKN axle sets-$250 shipped
All 4. 3 sets// 3 sets of 4 & one set of 2
rear & 1 front. All OEM GKN axles. Use
as cores or reboot & grease then ride.
56. urS driveshafts— $50 + shipping
I have 2. The one with good center
bearing sold.
57. Front subframe—$250 shipped
I have 4 in good shape//3 are
rust free. Still gloss black.
58. rear subframe—$250 shipped
Rust free—still gloss black
59. Non leaking urS steering rack—$150 shipped
Has a good boot as well.
1. UrS rack with torn boot & small leak—
$100 shipped
61. Rear spindles—$250 shipped
62. UrS hub set & 1 rear—
Fronts—$125 I have another set
One Rear— $60 shipped
63. front 26mm sway bar—$50 + shipping
64. urS strut bar—$50 shipped
66. urS trunk lid—$350 shipped
67. urS rear bumper—$250 + shipping
68. urS front fender liner set—$120 shipped
69. urS rear control arms—$150 shipped for both
70. box with every switch, relay, fuse,
module, and computer from a 93
urs4—$125 shipped
71. Front brake set—$250 shipped
Stock front calipers, caliper brackets,
slide pins, hardware, rotors, pads, steel
braided lines, and hardware.
72. Rear brake set—$250 shipped
Stock rear calipers, caliper brackets,
braided lines, and hardware. Will include
good ebrake cables.
73. urS factory ATE master cylinder with reservoir—$100 shipped
I have 3 and they’ll come with res cap & level
sensor with wiring pigtails
74. urS factory brake booster—$125 shipped
75. urS factory slave cylinder—$30 shipped
76. urS factory clutch master cylinder —$60 shipped
77. urS brake pedal—$60 shipped
78 urS clutch pedal—$60 shipped
79. urS gas pedal with no broken
plastic top—$125 shipped
81. urS power steering reservoir—$75 shipped
I’ll include the cap with level
sensor and the hardware/bracket
I have 3
82. Coolant reservoirs—$35 shipped
Will include cap, sensor, and wiring
pigtail—I have 3
83. Nice Windshield reservoir with pumps—$80 shipped
Will include lid, pumps, and wiring pigtails for the pumps
85. Factory aan k24 water & oil line set—$125 shipped
86. Nice Audi logo exhaust manifold heat shield—$100 shipped
87. urs4 a/c condenser—$50 + shipping
A/c blew ice cold
88. urs4 a/c pressure line set—$125 shipped
89. urs4 aan stock oil cooler setup—$125 shipped
Includes cooler, lines, air shroud,
bracket, & hardware
91.urs4 interior switch panel with all the switches—$100 shipped
92. urs4 aan factory crank cog/timing gear—$50 shipped
I have 3
93. urs4 aan factory cam gear—$50 shipped
96. urS rear diff crossmember—$125 shipped
97. urS IAC—$60 shipped
98. urS newer diverter valve—$30 shipped
710P code not updated 710N
I have 3
89. urS new n75–$30 shipped
99. urS aux water pump—$30 shipped
I have 3
100. urs4 black door cards—$250 shipped
101. Stock AAN maf boot—$100 shipped
I have 3 with no cracks
102. Black center console pieces—$150 shipped
103. Good factory coolant hose set—$100 shipped
Every single rubber coolant hose.
104. urS clutch fan setup—$150 shipped
You’ll get the clutch, fan blade,
fan shroud, and hardware.
105. urS A/C electric radiator fan—$75 shipped
I have 5 of them
106. urS rain trays—offers??
107. Trunk interior trim—???
108. urS clutch fan shroud—$75 shipped
Lots & lots of stuff.
the same time.
same time.
Aftermarket parts:
it forever.
Stock parts:
Working TPS,
I have two
Identical setup.
Have 2
bracket
Mint set
has no badge.
All 3 intact pieces
and wiring pigtails
I have 2 sets
1 set left
bearing sold.
$100 shipped
urs4—$125 shipped
good ebrake cables.
I have 3
pigtail—I have 3
A/c blew ice cold
bracket, & hardware
I have 3
I have 3
I have 3
I have 5 of them
- C07C450B-6725-4EAB-ABA6-11CE828BA22C.jpeg (1.94 MiB) Viewed 36312 times
- B01AA333-77F7-483C-983B-77B704664863.jpeg (1.22 MiB) Viewed 36312 times
- 29242806-6704-426E-8492-A26D013F69A1.jpeg (148.55 KiB) Viewed 36312 times
- A134CC6D-15EF-4A2B-B091-B86BE40BF0D4.jpeg (320.25 KiB) Viewed 36312 times
- FC20DAE9-0C3E-4E67-92F1-B55D1CC69C15.jpeg (317.45 KiB) Viewed 36312 times
Re: PARTOUT: 1993 Audi urs4//Pearl white on Ecru
Bump, taking offers...,
Re: PARTOUT: 1993 Audi urs4//UPDATED LIST & EVERYTHING IS OB
Updated list & everything is OBO...
