AAN Long Block (Southern, MN)
GreenMachine
Post by GreenMachine »
I have a long block with 205k on the clock. It's fine other than a bad headgasket. Car was not driven with the bad headgaket so was not overheated (shouldn't have a warped head).
Engine will come with the exhaust manifold, turbo, intake manifold, valve cover, and oil cooler/lines. (will not come with the fuel rail, coils, or throttle body.
Engine is located in Rochester, MN.
$600 Picked up.
