Eurovan AAF Deck Height
Post by AngryTaco »
Does anyone know off hand the specs to the AAF deck height? I'm ordering pistons this week. 2.5L Eurovan motor
mrdeye
Re: Eurovan AAF Deck Height
Post by mrdeye »
Maybe you can find some info on this link
http://www.eurospecsport.com/index.htm
Over on MG user DDG could probably give some info too. I’m not sure but he might be over with different user name??? I’m sure someone here knows but it’s not me.
:beer:
Mr.
Previous cars:
Post by ChrisAudi80 »
IIRC 236mm
236 mm for AAT & AEL, unsure of AAF.
if you are ordering custom pistons, measure youre damn block!!!!! it would suck to get customs and realize yours was skimmed
and CORRECTION per mr Hank its 236.25mm
^^^ agree on measuring first to be sure.
When I sent my TDI block to Hank, he was very diligent and measured everything just to be sure. Good thing, because he noticed the cc on the combustion chamber wasn't quite right with the supplied pistons and rods. Long story short, he deduced (via plenty of mathing, I'm sure) that the 160mm rods were no good and swapped them for 159mm rods to get everything back to butter. Proof of being a solid guy, he didn't even charge a restocking fee... and I didn't buy the DMF rods from him, Marcel did.
PRY4SNO wrote:^^^ agree on measuring first to be sure.
No disrespect to Hank of course, but I seem to remember that stock rod length for the 95.5mm stroke tall deck blocks is 159mm.
Post by AngryTaco »
We got it figured out. I bought a 12" caliper and measured. Jeff and I are working on pistons right now
Several measurements resulted in 9.333 - 9.335"
92.8 mm crank ;)
Craziness. Sorry for the trouble on that, Dustin.
Not at all! There's a learning curve to be expected when building a unicorn.
