FS: Innovative turbo in RS2 turbine housing
rallyfreak202
Post by rallyfreak202 »
SOLD
PRICE lowered. $1000 shipped.
Hey guys,
I have a pretty sweet turbo that is "bolt on" AAN/3B/RS2. I've since switched over to an EFR so I don't need this turbo anymore. $1200 shipped and insured. Pictures will be posted tonight.
Custom T4OE Innovative/Precision ball bearing turbo in RS2 turbine housing. 0 hours on complete rebuild. It is a TNX hybrid ball bearing system (hybrid means that a turbine-end journal bearing is used for hydrodynamic damping). It’s a solid system. Turbo was professionally overhauled with OEM parts (not shitty Chinese parts) and balanced post rebuild. Imbalance was <1.0g at a peak speed of 96krpm. The turbine map is actually published in the current Garrett Performance catalog, as a “GTW3476R” turbine; that is exactly the same 64/57mm turbine head that was used on this unit, so you could use that for reference if needed.
Comp inducer 48.5mm/exducer 74.75. (stock RS2 is 66mm exducer)
Turbine inducer 64/exducer 57 (stock RS2 is 59 inducer)
25psi by 3500RPM on a 2.5L 5cyl 20v. 380hp on 104oct with 36mm comp inlet restrictor.
If interested, email works best. nabragg034@gmail.com
Pictures album:
https://imgur.com/a/bplXy
Last edited by rallyfreak202 on Thu Nov 02, 2017 6:32 am, edited 3 times in total.
rallyfreak202
Re: FS: Innovative turbo in RS2 turbine housing
Picture album link posted
rallyfreak202
rallyfreak202
Posted on ebay. I'll take $700 shipped!
https://www.ebay.com/itm/Audi-RS2-custo ... 3288466421
