E85 @ Summit fuel lines.....
Posted: Sat Apr 01, 2017 4:22 pm
by type85
Braided lines are about 2 years old, don't remember brand, but probably Summit generic braided lines...
Car sat the whole time with E85 in the tank, started about every month to keep the battery charged.
https://goo.gl/photos/HxLz7ksXMY1hNYjz5
Re: E85 @ Summit fuel lines.....
Posted: Sat Apr 01, 2017 5:23 pm
by Noisy Cricket
Images not loading, but...
Never, ever, EVER store E85 in an unsealed container like that. If you're going to lay up an E85-running car for more than a month or so, pump it all out and refill the tank with gasoline and run it a bit to flush the lines/injectors out. That way it won't absorb moisture from the air and turn corrosive.
It's not nearly as bad as methanol but you still need to be cautious. This is why IMO any E85 car really should be done as a flex fuel setup. (Well, that and E85 isn't always 85% ethanol)
Posted: Sat Apr 01, 2017 5:36 pm
by mushasho
type85 wrote:Braided lines are about 2 years old, don't remember brand, but probably Summit generic braided lines...
Yeah, summit racing nitrile hoses are not merely enough protection against deterioration.
Swap out all fuel related hoses with PTFE conductive hose.
http://www.theprojectpad.com/viewtopic.php?f=11&t=13&p=53577&hilit=ptfe#p53577
Posted: Sat Apr 01, 2017 6:06 pm
by type85
You have a specific brand you can suggest?
by type85
Noisy Cricket wrote:Images not loading, but...
Yiikes!!
Yeah, learned my lesson!
Posted: Sat Apr 01, 2017 6:22 pm
by mushasho
I've purchased from these 2 places.
You can speak to Stuart directly Techna-Fit
https://www.technafitstore.com/category-s/1865.htm
http://anfittingsdirect.com/
Posted: Sat Apr 01, 2017 8:43 pm
Thanks for the links, Ob... fueling lines, fittings and intercooler piping is next on my punch list. Prices look good, now I just need to find a local supplier for comparison's sake.
