VEMS Bluetooth adapters now in stock
EFI-X Product development and new product releases
VEMS bluetooth serial adapters are now in stock so you can rock your VEMS via wireless communication to your laptop or Android enabled tablet / smartphone. Nothing says kick-ass-awesome like wireless tuning and fully configurable high res motorsports gauge pack :)
Re: VEMS Bluetooth adapters now in stock
Dude, ping the developers for dual outputs!!!!!! I must have this!
Hank wrote:Dude, ping the developers for dual outputs!!!!!! I must have this!
looks like there is quite a lot to do to make that work. what it would do is repurpose the serial interface that is currently used for the GPS feature in vems, but its currently RX only.
What you *can* do, is take your current serial setup you are using for your AIM, remove the TX pin, and 't' the ground and RX, wired to this bluetooth module. that will allow two AIM stream devices to talk at the same time without messing up the stream. For instance for your MXL and an android display simultaneous.
Now that would work. It would just be a matter of alternating Bluetooth duty between a laptop and the android device to tune right?
Hank wrote:Now that would work. It would just be a matter of alternating Bluetooth duty between a laptop and the android device to tune right?
yes.
There is a possibility you MIGHT be able to get your laptop without switching by giving TX to the bluetooth adapter, and using that to comm with your laptop. you'd have to shut down your android device first, since it only works paired to one device at a time.
This is teh awesome! I can't wait to utilize this :)
amd is the best
Post by amd is the best »
Tempting! Maybe I'll scoop one up at Carlisle from you.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
UrSobsessed
Post by UrSobsessed »
I'm interested in this! Will something like http://www.bestbuy.com/site/Rocketfish%26%23153%3B---Micro-Bluetooth-USB-Adapter/8820886.p?id=1207351932175&skuId=8820886 be enough to link with my PC?
Also, how is the connectivity with this? Anyone else running it?
I've been running this and it works very well. I hard wired it so the connection is always there - it's nice to be wireless.
That adapter should work fine if your laptop does not have Bluetooth.
UrSobsessed
When you say hard wired, are you referring to the usb port you put in the center console, or just the power controls?
power to the bluetooth module.
You can power it via 5v/1A USB port (from your laptop, for example), or it has a small power supply that you can wire to 12v for a permanent install.
UrSobsessed
Ok. Thanks.
The possibilities...
Fer srs
And now I need to own a tablet.
I have one bit I think wife would not be happy if I threw it in the 4k permanently
chaloux wrote:I have one bit I think wife would not be happy if I threw it in the 4k permanently
You could mount some kind of case with a quick release in the dash, and then you wouldn't have to have it permanently mounted... like how some head unit face plates pop off.
Yeah, easy enough. It'd be cool to have it rise out of the dash :hail:
Fundahl
Post by Fundahl »
Tested the software demo on Galaxy S4 and works great! How much for the kit in USA?
95 S6, 05 FZ1, 91 300ZX, 05 LJ Rubi
Fundahl wrote:Tested the software demo on Galaxy S4 and works great! How much for the kit in USA?
$79
http://www.efiexpress.com/catalog/product_info.php?products_id=113
