WTB: Holset HX35 turbo
Posted: Mon Jan 09, 2017 12:17 am
by morris400
Looking for a Holset HX35 turbo with 12cm housing. Starting to collect parts for a Holset build and kinda need a turbo lol.
Thanks guys.
Re: WTB: Holset HX35 turbo
Posted: Mon Jan 09, 2017 10:50 am
by Afterthought
morris400 wrote:Looking for a Holset HX35 turbo with 12cm housing. Starting to collect parts for a Holset build and kinda need a turbo lol.
Thanks guys.
I have an H1C if you have any interest in that. It's internal WG but has the blocker plate over it.
Posted: Mon Jan 09, 2017 12:47 pm
by vt10vt
Just call Goldfarb & Associates, a good HX35 core will run you $100-$150
Posted: Fri Jan 13, 2017 5:05 pm
Both good options ^^^
Posted: Thu Jan 26, 2017 7:59 pm
I'll sell you mine. Fully rebuilt 50 mm hx35 missing hotside. goldfarb could sell you the correct hotside you want for pretty cheap. I put probably 500 miles on it after rebuild. $150 shipped?
Posted: Thu Jan 26, 2017 8:15 pm
Not one problem with it. Rebuilt with turbolabs awesome kit from Amazon.com
BTW goldfab can sell you the 9 cm non-gated housing. That's what I ended up using.
Posted: Fri Jan 27, 2017 6:55 pm
by morris400
Wound up getting one from goldfarb. Hx35 with 56mm comp wheel and 12cm Non WG housing.
Thanks for the offer.
Posted: Fri Jan 27, 2017 7:16 pm
Good to hear you found the biggest one made. G&A, although a bargain, would only guess what size both holset I bought were. Never measured them and instead of getting that one the first the, they sold me the smallest hx35 ever made. I was...Happier after complaining.
Posted: Sat Jan 28, 2017 6:29 pm
by morris400
The guy I talked to said he measured it at 56mm. He said it's a hx40 wheel (which should be a 6 blade) but I'll measure it when it's here and see for myself.
He also told me it was just rebuild as well. All in $250 is not bad.
Posted: Sun Feb 05, 2017 12:22 pm
sounds like you got a pretty good deal. This the 56 mm I got the 2nd try. It made a full recovery lol, but not without hard work.
Posted: Fri Feb 17, 2017 11:53 pm
by morris400
That one looks beat the hell up. Mine came in today and it's damn near new. Hx40 8 blade comp wheel and housing, 12cm non WG ex housings.
Now I need to clean it up for sure, repaint the comp housing and sand blast the ex housing as well as tap the comp housing for WG.
Posted: Sat Feb 18, 2017 12:43 am
Sounds like an awesome score then. I'll never lie and say I've had good luck with the 91. I can count on 2 hands all the problems so far thatve been out of my hands lol.
Posted: Mon Feb 20, 2017 2:47 pm
Let me be the first to ask for *pics*
