Audi Coupe Quattro b3 Axles options
Zaworek
Post by Zaworek »
i wanted to check if any of you guys tired to use different axles on the coupe. Im entertaining few options and wanted to know if you came across any of the idea.
1. custom axles from DSS
2. using b5 s4 axles front and rear with custom length control arms.
3. using b6/b7 s4 axles front and rear with custom length control arms.
the question i have is will the outer axle joint will fit into the stock coupe wheel hubs
- Sebastian -
dana
Re: Audi Coupe Quattro b3 Axles options
Post by dana »
I can confirm b5 passat outers fit into the 20v knuckle, so i would assume the s4 would fit in there as well. Thats about as far as I got because I have tripod joints on my inners because of the TDI 01e.
speeding-g60
Post by speeding-g60 »
full custom like (but not) DSS Stg 5's.
