B3 ignition system (stage1 20vt EFI ignition)
Posted: Sun Mar 20, 2016 1:25 pm
I have upgraded from my MS2 system running off dizzy triggering to MS3X which uses a 60-2 wheel and CPS. I no longer need these, so thought it might be a good idea to offer them for sale.
What I have here is a 5 window distributor from an NG engine. Mileage is unknown on this, but it is in great shape and works perfectly. Also, the connector is not broken at all.
The cap on this is a Bosch piece with no more than 8k mes on it. The rotor is also a Bosch unit that is the correct narrow tip rotor from a 3b with no more than 1k miles on it. The wires are OEM VW/Audi with same mileage as the cap.
The coil is a nearly new Beru unit with maybe 1k miles on it. This will include the proper pigtail connector.
This is a great setup for anyone just starting a 20vt EFI build, or anyone needing needing good parts for their B3. I'm looking to get $200 shipped for these items.
Thanks or looking
Re: B3 ignition system (stage1 20vt EFI ignition)
Posted: Mon Mar 21, 2016 2:09 pm
by Fattyalx
If I werent going 034 fuel only I'd snatch them.
Posted: Mon Mar 21, 2016 2:14 pm
Fattyalx wrote:If I werent going 034 fuel only I'd snatch them.
Why go fuel only? you would still end up having to find a chip to improve the timing.
Posted: Mon Mar 21, 2016 2:26 pm
by Fattyalx
I was offered a setup with an older fuel setup, that includes a mac14 ecu that has a switchable timing between pump and race(how the guy that has it put it) So I assume like a daily driving ignition setup and a full power setup. Whole thing including the needed sensors(Minus FPR, fuel rail and fuel injectors) for $200 so gonna start out with fuel only and see how I like it.
Posted: Mon Mar 21, 2016 2:29 pm
Cant blame you for that price.
Posted: Mon Mar 21, 2016 3:42 pm
by Fattyalx
DE80q wrote:Cant blame you for that price.
Yeah; 200 plis shipping, 300 for fuel system and then install and tune for fuel.should be pretty good for efi and reliable. Good for a nice mild setup I think hoping I can achieve as close to 300 whp as possible
Posted: Mon Mar 21, 2016 3:53 pm
good luck with that. I will be hoping for about 350WHP with my HY35 setup. I don't remember the limit of the K24, but I know its not that high, without e85 or water meth injection.
Posted: Mon Mar 21, 2016 6:02 pm
Well you can count on it being a good-time wip in the least ;)
Bump for a great seller and knowledgeable fella
Posted: Mon Mar 21, 2016 9:06 pm
by Fattyalx
Maybe I'll change my goal to CHP hahah We'll see where it'll get me. Just want a nice quick daily haha Bump for good guy
Posted: Thu Mar 31, 2016 11:07 am
Bump
