So I've had Vems since November now and done about 3 different fuel tunes for my S4. First tune was on stock everthing using the target lambdas that came with the ecu. I was running only 15 psi at first to get my bearings with the Vemstune software. I quickly realized that the stock injectors were no fun and got deka 60's with an 044 pump(with a modded stock basket). That was when I retuned the car again with the 60lbers. This time I noticed some pinging or at least I think it was pinging at 15psi at around 5k. I checked and found I was running .85 at 15psi and 5k rpm. I then changed the targets for that boost level to .80 just to be safe.
I attribute this to some oil burning I am getting. Oil getting in the combustion chamber will lower the octane of the mixture and can cause pinging and det. I burn about a quart in 3k miles. Im hoping it is just vlave stem seals and I plan on doing a cyl head refresh soon.
-Will
