B4 90Q AFC V6 Idling issue
Posted: Wed Jan 13, 2016 9:40 am
Could use some help here determining an idling issue...
Car details:
Early Build, 1995, Audi 90q, AFC motor - all stock.
Symptons:
Car is idling fine... drives fine... pulls strong, but then if you let it idle for an extended period 5-10 minutes, it will just die - quickly.
No CEL, (It does light up when starting the car -as it should - so I know it works)
Haven't checked to see if there codes anyway... I suppose I could do that...
What's new:
Spark Plugs
Wires
Ignition Pack
Crank Sensor
Seems to me it must be something ignition related to fail so sharply? Thoughts?
Car details:
Symptons:
What's new:
Spark Plugs
Wires
Ignition Pack
Crank Sensor
