WTB: 01e clutch release fork and pivot/hold down hardware
dana
Post by dana »
I need the following in good usable condition. Thanks.
clutch fork
clutch fork pivot
hold down clip shown held in place with torx bolt
speeding-g60
Re: WTB: 01e clutch release fork and pivot/hold down hardwar
Post by speeding-g60 »
i should have something layin around with all the damned 01Es i take apart. remind me later tonight.
with 6 trans's and only use two at a time, i gotta have somethin.
dana
Post by dana »
i will send you a reminder PM this evening. Thanks.
Hey Aaron, or anyone else, have you ever seen different 01E forks for the release bearing? My old clutch that worked flawless on my setup isn't working on the new owner. It almost seems like his fork is deeper than mine was. I have no clue where my fork came from as I bought it separate from someone on here so we have been having a hard time sorting this out.
Sorry to hijack this post but it may actually be relevant :)
speeding-g60
Not me all the ones I have are or appear to be the same
Sent from my SCH-I545 using Tapatalk
Thanks Aaron
dana
Post by dana »
great question jim, i assumed all 01e's were the same.
I think everyone does. Just make sure you test clutch action before you bolt everything back together. Hank dug up a pic of two that were different, but neither helped the situation. It could be a failing master too for our problem.
