anybody got an early 5k parts car? need a 3.89 type 44 diff
Posted: Sat Oct 31, 2015 8:57 am
by Marc
I need a 3.89 rear diffy for an urs customer. etka says MC1 5000q should work. anybody got one of these land yachts rotting in a field and want to sell me a diffy?
Thanks.
Re: anybody got an early 5k parts car? need a 3.89 type 44
Posted: Sat Oct 31, 2015 12:40 pm
by deaner
I actually may have one in the parts pile. I'll have a look when I get home tonight.
Posted: Sat Oct 31, 2015 10:35 pm
by deaner
I just went out and looked. I'm fairly certain it's a 3.89 being as it came along with a trans and mc1. Would you know of a definitive way to tell?
Posted: Sun Nov 01, 2015 9:21 am
by Marc
What is the 3 letter code by the axle flange? That or the other way to do it is to pull the side cover and divide the number of ring teeth by the number of pinion teeth.
Posted: Sun Nov 01, 2015 10:58 am
by lorge1989
I have a 3.89 locker out of a B4 V6 car. It's a long nose which might be a different style than you need.
Posted: Mon Nov 02, 2015 12:31 pm
by vt10vt
Marc I have one I could bring down next weekend!
Posted: Tue Nov 03, 2015 7:32 am
by elaw
Marc wrote:That or the other way to do it is to pull the side cover and divide the number of ring teeth by the number of pinion teeth.
Wow you like doing things the hard way! ;)
Here's all you have to do: lock the diff, then rotate the input flange clockwise a bit to take up any play. Use a sharpie to mark a line across the input flange and case, and one output flange and the case - so you can accurately count turns on the flanges when they're rotated.
Then rotate the input flange clockwise and note how many times you have to turn it to get exactly 1 full turn of the output flange. It should be just under, or just over, 4 turns. If the former it's a 3.89 diff, if the latter it's 4.11.
Posted: Tue Nov 03, 2015 7:55 am
by Marc
sorta. in practice differentiating (haha. get it!) between 3.89 and 4.11 this way is harder than it sound. due to gear lash, having to make sure you rotate both flanges at the same time, etc.
Posted: Tue Nov 03, 2015 7:56 am
by Marc
vt10vt wrote:Marc I have one I could bring down next weekend!
sss ssss sss SOLD!
thanks.
Posted: Tue Nov 03, 2015 8:04 am
by elaw
Marc wrote:sorta. in practice differentiating (haha. get it!) between 3.89 and 4.11 this way is harder than it sound. due to gear lash, having to make sure you rotate both flanges at the same time, etc.
True... there's definitely not much difference between the two ratios.
But you don't have to rotate both output flanges if you can lock the diff. And technically if you were unable to lock the diff, you could hold one output flange in place, then count how many input turns it takes to make the other output flange do 2 revolutions. Although in some cases that would require 3 hands... :wtf:
Posted: Tue Nov 03, 2015 8:09 am
by vt10vt
sss ssss sss SOLD!
thanks.
Can't beat that for convenience factor! I'll bring her down Saturday, need a matching 016 or 5? I have a pile of those too haha
Posted: Wed Nov 04, 2015 10:00 am
by deaner
Heck yeah, that worked out!
Posted: Wed Nov 25, 2015 4:16 pm
by Wilford Brimley
Are those all TORSEN 3.89 transmissions?
Posted: Wed Nov 25, 2015 11:43 pm
by vt10vt
Wilford Brimley wrote:Are those all TORSEN 3.89 transmissions?
200 20v's had a 4:11 but any quattro 5k/20v 200 should be 3.89
My reference: http://www.motorgeek.com/viewtopic.php?f=15&t=8293
Posted: Fri Nov 27, 2015 9:54 am
by Wilford Brimley
I was more referring to your collection. I might pull a nick and start breaking input shafts off
Posted: Fri Nov 27, 2015 10:15 am
by vt10vt
Wilford Brimley wrote:I was more referring to your collection. I might pull a nick and start breaking input shafts off
Oh gotcha- I have at least 2 torsen 016's I believe and another 2 lockers, all are available!
Posted: Fri Nov 27, 2015 10:58 am
by Wilford Brimley
Are your T44 euro lights still available too?
Posted: Fri Nov 27, 2015 10:05 pm
by vt10vt
Wilford Brimley wrote:Are your T44 euro lights still available too?
Nope sold those a while ago now, sorry!
