First, the turbo:
Holset HX35 CHRA modified and converted to a 60/86mm billet cold side, 7+7, extended tip blade capable of flowing 79 LB/min @ 40 PSI
10 blade "Super 40" hot side and shaft from BAE, brand new.
freshly rebuilt following Holset's own rebuild procedures
8 CM^2 t3 flange hot side, ceramic coated
oil inlet converted to -6AN 90 degree
never installed, internally coated in motor oil then fogging oil for storage, still spins very freely by hand
$900.00 MANIFOLD IS SOLD! Thank you Afterthought!
4" inlet ITG Maxogen foam filter (velocity stack style) + Silicone coupler (for MAFless setup with turbo) will fit any 4" inlet turbo.
$100 for filter, coupler, clamps.
Package deal: If you buy the turbo I will throw in the filter too!
These items are heavy and/or awkward to ship, so the buyer is responsible for actual shipping cost.
