AAN longblock, harness, ECU, accessories etc
deaner
Post by deaner »
Selling my 242k mi COMPLETE AAN engine set. Came out of my 4k and I'm changing directions so this needs to go. Will include everything you'd pull out of a donor car for the swap(minus stock IC) along with a 7a oil pan and correct motor mount arm. Motor is stock and ran fine, aside from a coil that I think is going out. Would miss every once in a while. I'd already cut the DP to fit and just needs finishing. The motor is still in the car(does not run) and I may or may not continue on with building certain things for it, depending on where I'm at with pulling the new motor and whatnot from the new donor car. If it doesn't sell I'll stash it away for my street car.
Located in MN and at this point, direct shipping isn't an option. Just not enough free time for the next couple of months. Asking $1000 OBO and open to offers!
Thanks!
Edit: I lied! Doesn't include everything you'd pull out of a donor! The 01e isn't included. That's staying with me. :)
