Bills Scirocco 16v project
3bAudios
Post by 3bAudios »
ok, just picked up my new rocco yesterday.....its a bit of a fixer upper but i got it pretty cheap so i figure what the hell. Its a california car so no rust at all and i cant find any signs of an accidents so it looks to be a clean shell with only around 110k on it....for now i think i will just be bringing it up to snuff and getting it back to NH before i debate weather or not to build it..
yay! got the images to work.....
Image[/img]
Toxcheap
Post by Toxcheap »
Link those pics, what you waiting for?
audidub
Post by audidub »
sounds like a good base to work off of, any car that hasn't lived in new england is a good car though. let me know when your back in nh i'm just over in unity. good luck with the dub. :cheers:
3bAudios
Post by 3bAudios »
I tried 3x but it just kept giving me error messages...attempt #4[/img]ok this is the message....
Warning: opendir(/var/www/vhosts/motorgeek.com/httpdocs/phpBB2/gallery2/g2data/albums//3baudios/Rocco): failed to open dir: No such file or directory in /var/www/vhosts/motorgeek.com/httpdocs/phpBB2/g2image/g2image.php on line 183
Cannot open Gallery2 data directory.
Current Album: Motorgeeker Gallery / 3baudios / /
Cannot get the Gallery2 ID for the requested path.
This is most likely due to a file or directory residing in your Gallery2 data directory structure, but not being registered in Gallery2 as part of your album structure. All the rest of the functionality on this page will work.
Here's the path that is invalid: /3baudios/Rocco
There are no photos in this album.
Please pick another album from the navigation options above.
Attachment ( 7193 ) : rocco3.day 1 001.jpg
audiPete
Post by audiPete »
Bill:
Those pix bring back memories of my early '86 Silver/Black one!!!
I installed one of the first TT 16v exhausts in that car, and boy do I miss that growl!
I don't miss the "self machining" vw transmission though...
-Peter
HT Motorsport
Post by HT Motorsport »
:woowoo: Congrats Bill
Cant wait to see that thing with 200TQA running gear in it ;)
H
3bAudios
Post by 3bAudios »
I still cant decided if i should keep it or not....i know vw's and i built my other scirocco an have a set of pistons for it already.... but i sort of want to finish my 90 which means this should stay a DD...i dont know.....to may projects to little time.....
Right now I just want to get it up and running well, it is running a bit rough and has trouble firing at first, although the injectors are new so they shouldnt be leaking to bad...
anybody know anything about that error??? i still cant add the pics...
3bAudios
Post by 3bAudios »
Ok, worked on the car a bit today, both of the adjusters for the seats were very messed up and clogged, got those cleaned and lubed up, now the seats adjust nice....also the passengers seat didnt want to fold forward so i had to make some adjustments to make it work again...then i just cleaned up the interior....
when i go to start it i have to crank it for a while and give it some gas to get it to fire and then once it is up and running well i cant do any more than crack the throttle or it wants to die and it pops through the intake once in a while.....but once it warms up it it gets a bit better....will have to mess with it a bit later on and tomorrow
and i still cant put any images from my scirocco album in here....
audidub
Post by audidub »
even though they are new injectors there might have been crap in the lines and they are leaking already. you may want to pull the lines and clean them out and see of there is any rust under the band joe fittings in the fuel distributer. also once its warm and running well try unpluging the preasure regulator on the side of the fuel distributor and see if that makes much of a difference, iirc those have a fail safe so if they crap out they will let enough fuel through so it runs but not really all that great. you may wanna verify this with the bentley. and if you don't have one definatly get one. good luck
ryan
3bAudios
Post by 3bAudios »
Well it seems that the injectors feel a bit loose on the drivers side, only the left two seem that tight, the right two seem a bit loose. Dont know about crap in the lines, would be a bit surprised as this car is petty damn clean, no rust anywhere on the fuel dizzy.
audidub
Post by audidub »
that is another common thing with the older cis cars, the injector o-rings they can cause a vacuum leak, other then that check all the other vacuum lines the old vw braided lines don't hold up much past 10-15 years
3bAudios
Post by 3bAudios »
ok, today i put on 2 cv boots on the large passenger side axle, next is going to be the new struts.....took the intake back apart again and found a small hole, vacume leak in the intake boot....is running much better and hopefully will be ready for the trip cross country soon....
3bAudios
Post by 3bAudios »
ok, update time........things i have replaced...oil pressure switches, coolant gauge sender, fixed a vacume leak in the intake boot, removed the ISV, replaced the shift bushing that they had used duct tape to try to fix with a mk2 one, just had to shave it down a bit to get it to fit, got the old tierod out, put in the new front suspension, removed the PS belt, installed the poly front motor mount, i pulled the cluster to try to get the dash lights to work, but with no success, and i think thats about it......almost ready to start the LONG drive to florida and then up to NH....
HT Motorsport
Good luck Bill...thats a loooong drive.....
Cya whn you get here.
H
3bAudios
Post by 3bAudios »
Yea, it will probably be a little while, but ill get there eventually and you KNOW i'll want to check out the serious progress you've been making on the v8
3bAudios
Post by 3bAudios »
ok, i havent updated the scirocco page in a LONG time but here is a quick recap. It made it from ca to fl then up to NH where it is now. It lost reverse along the way but is still running strong. It got a new sunroof along with some nice rear speakers and a sub courtesy of my old 200 20v. I custom fabbed up a crank case breather setup that i got the idea from my buddy ivan back in fl. I also pulled the tranny from a mk3 jetta 2.0 and replaced the fluid with some redline and am going to be throwing it in car i lew of fixing the existing transmission, and for 50 bucks how can you go wrong?
3bAudios
Post by 3bAudios »
Well while driving the Rocco to the next town over last week I heard a loud bang, not driving it hard, revving it up just normal driving....the car still would run, but was running real rough and the oil light started flashing so i shut it off imedatly and called AAA, didnt have time to look into it till today and this is what i found when i pulled the pan.....
guess I'll have some work to do on it after apple season is all over this year....
Longitudinal
Post by Longitudinal »
Wow. I have never seen a whole rod ejected like that. Took the oil pump drive gear with it. Wow.
Post by AudiSport4000 »
That is quite scary...
90_Koop
Post by 90_Koop »
Gnarly! :frustrated:
Justin517
Post by Justin517 »
WOW dude, sorry to hear that! By the way, I finaly started a project thread on the Ivan-built then sold to jared and now its mine...coupe, hopefully will get it running over the winter.
death 4kqt
Post by death 4kqt »
holy crap! That is impressive :roll:
3bAudios
Post by 3bAudios »
Yea, I thought i was pretty crazy myself, the craziest part was that the car still ran....although it shook real bad at idle....anyone have a good 1.8 bottom end? LOL
HT Motorsport
Holy Crapola Bill thats impressive!!!! DAMN! :frustrated:
Well I guess its time to find a junkyard motor for the racecar project. I am in the UK right now but if you need some help when I get back you know where I am.
H
3bAudios
Post by 3bAudios »
Yea, I have a set of 5 low mileage MC pistons and rods that I could drop in to another 1.8 bottom end, OR.......I could drop in the extra 2.0 bottom end i have here in it but then it wouldnt be able to take boost that well but i dont know if i have the time to boost it anytime soon anyway......so i guess i could just swap the 2.0 in there and leave it CIS .................i dont freakin know, i really need to try to finish up the megasquirt II on the 90 right now then i'll deal with this problem later
