FS: Parting 00 C5 2.7t, BW K04s, GIAC Stage 3 ECU, etc...
iammrfancypants
Post by iammrfancypants »
Hello I am parting out a 2000 Audi A6 2.7T quattro. Silver in color with grey interior. Has OEM Xenon headlights and the body is in very good shape. No real damage on it and no rust (California car). Was parted out due to a bad clutch and headgasket failure. 130k on the chassis.
Not available:
y-pipe
MAF housing
intake
injectors
fuel rail
valve covers
EGT sensors
intercoolers
rear diff
taillights
grille
side mirrors
catback exhaust
transmission
driveshaft
pedals
front axles
Everything else is available. If it is not listed more than likely I am not trying to get much for it. Looking to junk the car ASAP so if you need/want anything make me any offer.
Engine, 130k was told it needs headgaskets but not sure, no signs of headgasket failure. All accessories, complete minus pieces above as "not available" - $500
034 motorsport snub mount with cage- $40
GIAC 1.5bar K04 ECU (M-box, hitachi MAF) - $300
GIAC flashloader for ECU - $80
Clutchmasters lightweight flywheel used for 15k - $250
Clutchmasters pressure plate for stage 4 kit used for 15k - $200
Borg Warner OEM RS4 K04 turbos. No shaft play, blades in excellent shape, used for 15k miles. Comes with OEM RS4 K04 inlets - $1500
Milltek downpipes with race cat - $600
H&R Street performance coilovers for B5 A4/S4, used for 15k in good shape - $700
TSW Bremma 18x8 ET32 wheels (clear coat is peeling, small scratches, no curb rash) with VERY good condition Eagle GT tires 235/45/18 - $700
B5 A4/S4 OEM Euro Valeo Xenon headlights with broken tabs - $250
