So i'm having some weird map sensor issues and I'd like to recalibrate it to remove that variable, but I'm at almost 5000 feet elevation here. Do I go off the normal calibration of trying to get the map to read 101 at engine off or should I adjust depending on my elevation because pressure is lower up here?
Something I've always wondered but never bothered to figure out....
Calibrating map sensor at elevation.
Re: Calibrating map sensor at elevation.
Umm, wouldn't suggest that.
Fix the issue.
Can you make load equal to MAP/baro?
Fix the issue.
Cheers, Brady
72 240Z 123whp
www.dynodoc.ca
72 240Z 123whp
www.dynodoc.ca
Mine always read <100 @5280'. I'd leave it.
