FS: Audi Sport wishbones replicas
Posted: Sun May 03, 2015 3:41 pm
by Albertracing
Audi Sport Quattro S1 replica wishbones for front and rear axle. Versions for B2 and B3/B4 divided column available. With high attention to detail, this is the best replica wishbones available.
Price is 1495 usd with shipping to US/Canada.
What’s Included:
– two wishbones for front axle
– two wishbones for rear axle
– four aluminum ball joint carriers milled on CNC machine and anodized in silver
– four maintenance free sport Fluro bearings (22 mm hole)
– four steel pins to connect with OEM struts (for Audi Coupe Quattro 17 mm, for Ur-Quattro 18mm)
– eight steel galvanized locking plates for securing aluminum ball joint carriers
– all necessary screws for mounting ball joint carriers and steel pins
Features:
– Can be used in conjunction with the standard front/rear sub-frame
– Made to work with OEM uprights (quattro B2/B3, ur-quattro)
– Allows for massive camber adjustment (up to 25mm more versus OEM) and wider track
– Gives additional caster. Audi B2 OEM caster is 1,25 and with our wishbone it is 2.65
– Works fine with Audi Sport blade type anti roll bars
– Works with Audi Sport uprights (22 mm bolt)
– Prepared to work with additional trailing arm (both in front and rear)
– Possible to use with “turn stop” on Audi Sport uprights
– On the contact area between aluminum ball joint carrier and inside of the wishbone the area is knurled for better grip of the carrier
– To be used with 37mm diameter bushes for mounting the wishbone to the subframe
More information at https://www.akmotorsport.net/product-ca ... wishbones/
Re: FS: Audi Sport wishbones replicas
Posted: Mon May 04, 2015 6:15 am
by lorge1989
Well done. :hail:
Posted: Thu May 28, 2015 5:00 pm
by the german
sweet! these are cool.
