single piece drive shaft?
I have a 91 200QT. I know someone out there makes a single piece drive shaft. I looked at the drive shaft shop I don't need a fancy carbon fiber one. A local shop said they would cut up my o.e one and make one for $600 but won't warranty it after its made. I could also just get a replacement o.e one for $500. I have to believe that someone out there makes one with a warranty for about that price. Am I wrong? I don't have any lofty power goals for the car someday I'd like to be in the 400-500hp range so it would be nice if I didn't have to change drive shifts again. Thanks for the help.
Re: single piece drive shaft?
What's wrong with your current driveshaft?
Center support is thrashed and the CVs are old and crusty.
- speeding-g60
find a used one? i push ~900 awhp thru a stock 4kQ driveshaft, completely stock, launched and drag raced HARD.
WI-3B-200 wrote:I have a 91 200QT. I know someone out there makes a single piece drive shaft. I looked at the drive shaft shop I don't need a fancy carbon fiber one. A local shop said they would cut up my o.e one and make one for $600 but won't warranty it after its made. I could also just get a replacement o.e one for $500. I have to believe that someone out there makes one with a warranty for about that price. Am I wrong? I don't have any lofty power goals for the car someday I'd like to be in the 400-500hp range so it would be nice if I didn't have to change drive shifts again. Thanks for the help.
Nobody offers a 1 piece driveshaft for any T44 or C4 car...they are to long and under load would vibrate or wobble....Hence the 2 piece with carrier bearing is the only option. I'm sure one could be made out of carbon fiber for $1500-$2000 for you...but why?
- ringbearer
Looking like I'll just rebuild it. Was hoping for an alternative. Thanks for the assistance guys.
DE80q sent you a PM
