AAN engine harness
AAN engine harness
Post by Afterthought »
Purchased this for a swap and didn't end up needing it.
150 + Shipping
Wilford Brimley
Re: AAN engine harness
Post by Wilford Brimley »
I literally just sold mine for the same exact price. After seeing what ABY harnesses go for, I might have to buy an AAN harness again and make it work
The sad part is this was sold to me as an ABY harness, so I'm losing money no matter what. Got ripped off :(
What are you swapping into? it is a pain in the ass to splice the harnesses but its also a pain in the ass to find an ABY harness .
It only takes about 6 connections to the CQ fuse box to get your engine running with an AAN ECU and harness, It can be done for other cars too.
Probably a few days of wiring.
glibobbo21
Post by glibobbo21 »
few days? say whaaaaaat?
Wilford Brimley
Afterthought wrote:What are you swapping into?
88 90Q, but I'm running a 20vt with coil on plug ignition.
glibobbo21 wrote:few days? say whaaaaaat?
It takes a long time to get everything sorted out and figure out what you have. I started from a disadvantage though because I didn't remove the old wiring . So I had to figure out what was and wasn't there.
varia
Post by varia »
¯\_(ツ)_/¯
project 2226
