The bad... Both are missing headlight bulb retainer clips. One is missing the rubber dust grommet that covers the back. Driver side glass has a penny-sized chip on the inside of the glass.
The good... Passenger side glass is perfect. Both reflector buckets look like new, no signs of moisture, debris, rust, or anything. Both have protective film on the glass. Both have the city bulb holder. Both have brackets with all adjusters and tabs/mounting points in great condition.
These are a great upgrade to the stock US headlights.
$200.00 I do not want to ship these. Local pick up only in Auburn CA, I'm willing to drive a reasonable distance to meet someone to help accommodate. If you are in the PNW I can get these safely up to the Salem/Portland OR area for free.
F/S 2-peice Euro H4 Headlights for 4k/CGT
- P1060269.JPG (169.69 KiB) Viewed 6367 times
- P1060268.JPG (160.72 KiB) Viewed 6367 times
- P1060267.JPG (166.6 KiB) Viewed 6367 times
Dan
1984 Ur quattro
1987.5 Coupe GT Special Build
1984 Ur quattro
- ringbearer
Re: F/S 2-peice Euro H4 Headlights for 4k/CGT
Honest seller
Thanks Dan
If it makes a difference, the only reason I don't want to ship these is I've seen too many headlights destroyed from mishandling and these are nice enough that I don't want that to happen to these. Maybe I can be talked into it if someone wants them bad enough.
Dan
1984 Ur quattro
1984 Ur quattro
