Comp Turbo 5858, SPA manifold and downpipe for B3 90
Posted: Thu Oct 02, 2014 7:23 am
by lorge1989
-3" Inlet 2" Outlet for the compressor, 1/8" NPT tapped hole
-T3 Flanged, AR is .63 on the exhaust I beleive, I will have to double check.
-Upgraded billet compressor wheel
-oil cooled
-18 months old, the bearings got loose so I called up and Comp and had them fully rebuild it. Comes with a 12 month warranty from them. I'm not sure its technically transferrable, but if the buyer has any problems I have no issue with them sending it back in my name.
I made 23 psi by 4500 with this turbo on a 2.0 20V with a small port head. I have no dyno figures but my calcs show that at 23 psi on this turbo I was making ~475 bhp.
If anyone has a B3 90 (1.8T swap only) I have a downpipe that will work great for it, vbanded on both sides and has a bracket that mounts it to the transmission, plus a SPA manifold. If you want all three I will sell all of them for $1100.
This downpipe took many hours to make and is fully wrapped. Note the only mod you need to make for this to fit your 90 is a slight modification to the the tie rod. I slightly bent mine and cut abou 1/3 of the material off of it then inserted a solid rod in the hollow center of the tie rod and welded it back up. I also have a wastegate setup for this too, a pipe that goes from the manifold to the wastegate then a dump tube. If you are interested in everything I will consider selling it all.
The only reason I want to sell everything is I figure I need to make a new downpipe anyway for the new turbo I am getting so if someone wants the whole setup be my guest.
Re: Comp Turbo, SPA manifold and downpipe for B3 90
Posted: Thu Oct 02, 2014 7:37 am
by mushasho
Size?
Re: Comp Turbo 5858, SPA manifold and downpipe for B3 90
Posted: Thu Oct 02, 2014 8:36 am
by lorge1989
Sorry about that, 5858. Rated for 600 HP by comp.
Posted: Thu Oct 02, 2014 10:35 am
by scubagli
DP 3"?
Posted: Thu Oct 02, 2014 11:01 am
by lorge1989
Yes, 3".
Posted: Thu Oct 02, 2014 12:00 pm
by scubagli
Would you consider selling it separately? If so price?
Posted: Thu Oct 02, 2014 12:06 pm
by lorge1989
What are you looking for the downpipe?
If I was to sell things separately here are prices. Everything is best offer, I'm willing to work with ya.
Turbo : $650
Downpipe : $200
Manifold : $250
Posted: Wed Oct 08, 2014 7:01 am
by lorge1989
Turbo sold.
