So I have picked up a couple used bilsteins for my coil over setup, but none have come with the retaining nuts. Is there a supplier that I can order these from? I have tried to seach this with no luck. These are for a 91 B3, so fronts are 50mm and rears are 55mm.
Thanks for any advice.
Bilstein insert nuts
Re: Bilstein insert nuts
I would think any Bilstein distributor could point you in the right direction.
- ringbearer
I'm in the same boat but for a C4, Shox.com quoted me about $30 each + shipping. I emailed them with what I needed and they got right back to me.
I think you mean the gland nuts...bilstein tech support can sell them to you..
Yeah, the gland nuts. I will have to try to call them.
