UrS4 Under dash power posts, question
Draky
Post by Draky »
Finishing the install on my radio system right now and I just realized I don't really know which posts to use... I pulled the covers at the driver's knees (pic below) and was told to use post 15 for ignition source. Is there a post I can use for illumination? The posts are numbered the following:
30, 30a, 58a, 75x, 15a, 75a,15
And almost forgot to mention, this is on a 92 UrS4
Thanks again for the help guys! You guys always ROCK!!
morris400
Re: UrS4 Under dash power posts, question
Post by morris400 »
I used 75x for my boost gauge install. Not sure if it helps but thats what i used. It works for the gauge light.
2016 VW GTI DSG Daily Driver
2001 B5 S4 Stg 3- (Gone)
Draky
Post by Draky »
So 75x gives your gauge light when you turn on the lights on the car?
if you have a Bentley its easy to chase down the dimmer switch wire
Draky
Post by Draky »
I do not have one.
Draky
Post by Draky »
Anyone with a Bentley care to help me out? Just trying to verify post for illumination, think it may be the 75x.
scubadave
Post by scubadave »
you know, you could always try probing that post and others with a test light or DVOM to see what it does when cycling the key, turning on the lights, playing with the dimmer ect.
75x is switched 12v
dana
Post by dana »
just start probing around with a multimeter and find something that switches on with the lights and drops voltage with the dimmer. Easy.
Draky
Post by Draky »
dana wrote:just start probing around with a multimeter and find something that switches on with the lights and drops voltage with the dimmer. Easy.
Problem is I recently moved and can't find my multimeter.
dana
Post by dana »
bummer! I can't live without mine.
morris400
Post by morris400 »
Draky wrote:So 75x gives your gauge light when you turn on the lights on the car?
Yepers
UrSobsessed
Post by UrSobsessed »
There should be a source in one of the wire harnesses for the stock HU. If you want it to operate with the head lights, and dim with the rheostat on the instrument cluster, then tap into the wires for the ashtray light. I tapped those for my boost gauge so it goes along with the dash lights.
Yepers
No, 75x is switched 12v. If the ignition is on, it is hot.
Like Dace said, if you want it to turn on with the headlights and dim, ashtray is the easiest source
