7a flywheel pin replacement location HELP!!!
Posted: Sun Jun 22, 2014 8:41 am
by my2000apb
ok background, we have a fidanza LWFW with a broken 7a style timing pin. as VEMS seems to play nicer with the large urS timing pin vs the small 7a pin, we went ahead and machined a new urS style pin. now we just have to locate it on the flywheel.
I know vems has the control to move the pin location. so do I want to move the pin ~2 teeth in WHICH DIRECTION?
I certainly don't want to repull a trans to get it right ahahah
thanks!!!!
Re: 7a flywheel pin replacement location HELP!!!
Posted: Sun Jun 22, 2014 10:10 am
Why not just remove the broken pin, and use the original hole? Not hard to do, I have removed a few of them.
Posted: Sun Jun 22, 2014 10:18 am
by my2000apb
hole is knackered
Posted: Sun Jun 22, 2014 10:35 am
Send me a pic. I can probably fix it.
Posted: Sun Jun 22, 2014 10:38 am
by my2000apb
yeah but we can just put it back in two teeth off and set the tooth offset in vems, DONE
just want to know which direction is better to go, clock or counterclockwise
Posted: Sun Jun 22, 2014 10:47 am
gotcha, for me I would just rather try to keep in in the original spot. proceed.
Posted: Sun Jun 22, 2014 10:51 am
by my2000apb
DE80q wrote:gotcha, for me I would just rather try to keep in in the original spot. proceed.
yeah it would be quite important for oem eng mgt
but as we can manipulate via vems where the pin is we can put it wherever. although it needs to be in a certain "window" as far as I know so just not quite sure what direction is safer to go
Posted: Mon Jun 23, 2014 9:59 pm
The window is huge, look primary trigger settings (visual) in base setup. You can also manipulate it with a certain setting that I forget the name of. But you have like 60-90° I think, just open VEMS up and you'll see.
Posted: Mon Jun 23, 2014 10:03 pm
Oh, that setting is called "distance between zero tooth and the trigger"
So if you're outside the 60-127° window (correction to upper post) you can move that slider and get it in the window.
So you can kind of put it anywhere
Okay not anywhere but anywhere close to the original will be fine.
Counter clockwise on the flywheel would be preferred. Clockwise on a front trigger wheel.
Unless I'm wrong. LOL
Posted: Thu Jun 26, 2014 9:59 pm
by MHCAudi200t
Im not sure if this will help. I dont recall what this flywheel was of off but i came across it while searching for answers about a no start issue i was having on my 20vt.
