Page 36 of 55
Re: Darin's 80tq...255's...
Posted: Tue Dec 11, 2012 8:05 am
by quattro87
Is it done yet?
Quit showing off the KWs already and get this back on the road! :wink: I gotta say, I will be a bit jealous of all that rubber when you are rolling again. Nice!!
Re: Darin's 80tq...fuel line fittings...
Posted: Tue Dec 11, 2012 8:47 am
by RSCoupe
Audilard wrote:Image
You could gain another couple millimeters if you switch to heim joint tie rods.
Posted: Tue Dec 11, 2012 9:59 am
by PRA4WX
Audilard wrote:More pointless pics of my car. I'm really liking these gunmetal wheels on the black car with the s4 skirt. It's really going to look good with the upper door trim removed, B4 rears and fresh paint....
RS2 mirrors would be sweet too..
....and 255's. Here are the fronts with the 235 track tires and a 10mm spacer:
Those 235/40's are more like a 245, so what's another 10mm? :wink: I can get the fronts to work...
I think I'll sell my other ABT's with the 235/40 Dunlop Star Specs. 17x8 25mm offset. Gotta buy some Azenis!!
They look aggressive and are cheap enough, but i dislike the 615's a fair amount. Poor performing tire for me.
Posted: Tue Dec 11, 2012 10:37 am
by Audilard
The 245/40/17 tire is quickly becoming irrelevant in the tire market. There are fewer and fewer options out there for that size. The best tire in that size was the Dunlop Direzza Star Specs, which Dunlop is no longer making. Those are what I really want, but won't be able to find that tire anymore. I can't find anything really comparable. Here is that tire on my wheels in 245/40/17.
Posted: Tue Dec 11, 2012 10:44 am
by Audilard
245/40/17 options:
Toyo Proxes R1R
Ventus R-S3
Potenza RE-11
Opinions?
Posted: Tue Dec 11, 2012 11:01 am
Where did you get the info the direzza is discontinued? I am gonna keep my tirerack eyes peeled for when those go on clearance. There are still lots of 245-40-17 tires though, far more than 255-40-17s. I really liked the hankook v12s. Awesome budget tire, and 255-40-17s fit well on 8" wide wheels. The direzzas in 255s are too wide for a 8 wide imo.
Posted: Tue Dec 11, 2012 11:05 am
by my2000apb
those direzzas seem to run a size wide all arouynd
Posted: Tue Dec 11, 2012 11:23 am
by Audilard
ShavedQuattro wrote:Where did you get the info the direzza is discontinued? I am gonna keep my tirerack eyes peeled for when those go on clearance. There are still lots of 245-40-17 tires though, far more than 255-40-17s. I really liked the hankook v12s. Awesome budget tire, and 255-40-17s fit well on 8" wide wheels. The direzzas in 255s are too wide for a 8 wide imo.
Tirerack already lists them as discontinued and you can't find that tire in 245 anymore.
Posted: Tue Dec 11, 2012 12:24 pm
by Audilard
I just went to two EVCOs and they weren't any help. The only -6 fittings they had were brass with yellow caps. Guess I'll order from Summit.
Posted: Tue Dec 11, 2012 1:14 pm
I like the HTRZIII, cheap, good treadwear.
http://www.tirerack.com/tires/tires.jsp ... &tab=Sizes
Posted: Fri Dec 21, 2012 5:32 pm
by savagerocco
Is this thing running yet? :hide:
Posted: Fri Dec 21, 2012 6:52 pm
by Mentosman42
I second the v12's. Got a set from tirerack with a $80 or $100 rebate a while back, great bang for your buck.
Posted: Fri Dec 21, 2012 7:33 pm
by nsimps
savagerocco wrote:Is this thing running yet? :hide:
:stupid:
Posted: Sat Dec 22, 2012 6:14 pm
by Audilard
Nope
Posted: Sat Dec 22, 2012 6:21 pm
by mrmotorhead13
FWIW I have RS3's on the track Miata and they're great. Stick well and wear well both.
Re: Darin's 80tq...no fuel...
Posted: Mon Dec 24, 2012 11:39 am
by Audilard
Got it all together and went to start it. It cranks over just fine, but the fuel lines aren't pressurizing. After some cranking I check the fuel rail lines and there is not fuel in the line.
Posted: Mon Dec 24, 2012 12:27 pm
by quattro87
Won't run without gas!!
Posted: Mon Dec 24, 2012 12:36 pm
Might wanna look at the pump. Going lean at WOT would explain a lot. Jump it with 12v and see if it runs
Posted: Mon Dec 24, 2012 12:37 pm
by Audilard
Good news. Got it fired up. Bad news. It's blowing white smoke like a locomotive.
Re: Darin's 80tq...fired up, but...
Posted: Mon Dec 24, 2012 12:51 pm
by savagerocco
Blown head gaskets always smoke until you get the coolant burned out of the exhaust
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Posted: Mon Dec 24, 2012 1:17 pm
by death 4kqt
Darin, did it smoke right away after starting, or after running a bit and getting some heat in the exhaust? If the latter, then it its probably just coolant from you prior mishap burning off, as Brent said. I had the latter happen after a headgasket issue on my 3b 90.
Posted: Mon Dec 24, 2012 3:11 pm
by Audilard
It got more smoke as it warmed up and I let it run for a while at about 3k rpms. It has tapered off significantly so I hope it's just about all burnt off.
Posted: Mon Dec 24, 2012 3:22 pm
Panic! Nevermind. Whew..
Posted: Mon Dec 24, 2012 4:16 pm
by nsimps
I'm sure it'll be fine :) glad you had some wrench time, especially this close to Christmas!
Speaking of white smoke behind cars, mine did that the other day... :(
Posted: Mon Dec 24, 2012 5:06 pm
by quattro87
Did the smoke smell like rubber? :wink:
