2.0L20v90Q...white wheels it is!!
1990 4cyl20v 90q...DYNO 648hp 508tq
I have been under the assumption that the I5 20v was a 16v with an extra cyl. Are the heads really that different?
death 4kqt
Re: 1990 4cyl20v 90q...DYNO 648hp 508tq
Post by death 4kqt »
they are the same, but the 16v is much more plentiful and thus cheaper.
Jiggle_Billy
Post by Jiggle_Billy »
Mcstiff wrote:I have been under the assumption that the I5 20v was a 16v with an extra cyl. Are the heads really that different?
You are correct in your assumption.
Price out a 16v vs a 20vt motor for building up. I can get a 9a motor for damn near free, then promptly hit up vwvortex for a pile of aftermarket parts.
I'd be stuck paying a fortune to build up a 20vt I5 when compared to a 16vt
bdcoombs
Post by bdcoombs »
4cyl ftw
Jiggle_Billy
The sound just isn't the same though....
I guess you are talking building a 7a for >~350whp. Otherwise I don't see what parts are expensive. From what I can tell the 7a and 9a pistons are the same.
I'd go further but this it getting OT.
Zerb
Post by Zerb »
a good friend of mine, the kid who did all the welding for this project, has a built 16v in a mk2 with a precision 6262 t3 on tec3 and an sqs trans. should make some power that as well soon here.
dspl1236
Re: 1990 4cyl20v 90q...just got back from DYNO 648awhp!
Post by dspl1236 »
speeding-g60 wrote:WOOHOO!!!!! 648.....
try driving with THAT on the streets haha....
looks easy :drive: :D
Zerb
Post by Zerb »
once i get some new front tires and an alignment, ill have the gopro charged and recording. :woowoo:
Jiggle_Billy
Time to go pick on liter bikes....
Zerb
Post by Zerb »
i like how you think
Granted the dyno could be different, but 600whp is about when I started to get a majority of the newer liter bikes. My only loss was to a new piped and ECUed 1000gsxr. He was a couple of lengths to 130 faster than I was. An extra 48whp on top of aerodynamics that aren't similar to a brick should help a bit!!!! Impressive torque as well!
Frank the quattro tank
Post by Frank the quattro tank »
Mcstiff wrote: I guess you are talking building a 7a for >~350whp. Otherwise I don't see what parts are expensive. From what I can tell the 7a and 9a pistons are the same.
Not quite... assuming zero deck height when assembled, the 7a pistons are about 3.2mm taller than the 9a, due to the 9a's 92.8mm stroke vs 86.4mm for the 7a. The 1.8 Pistons are identical in terms of height, but have the smaller 81mm bore.
Frank the quattro tank wrote:[/quote]
Not quite... assuming zero deck height when assembled, the 7a pistons are about 3.2mm taller than the 9a, due to the 9a's 92.8mm stroke vs 86.4mm for the 7a. The 1.8 Pistons are identical in terms of height, but have the smaller 81mm bore.[/quote]
I was referring to strength (cast).
Zerb
Post by Zerb »
ShavedQuattro wrote:Granted the dyno could be different, but 600whp is about when I started to get a majority of the newer liter bikes. My only loss was to a new piped and ECUed 1000gsxr. He was a couple of lengths to 130 faster than I was. An extra 48whp on top of aerodynamics that aren't similar to a brick should help a bit!!!! Impressive torque as well!
im hoping my weight helps too. once i get new tires on the front and a proper alignment, im going to finally put the car on corner scales and see what it weighs.
bdcoombs
Post by bdcoombs »
the lighter engine and being able to make 600+ is what sold me on a 4cyl. and cars like this.. thanks for the motivaiton
Zerb
Post by Zerb »
got to run my buddies gsxr 1000 today, up a nice hill at lol. only ran 34psi, noticed later on in the logs that the egt sensor for the ecu was getting a choppy signal and thus limiting the boost controller duty cycle, no biggie we can go again. from a dig next time too. enjoy.
Link to video
Re: 1990 4cyl20v 90q...VS. GSXR 1000
once again,
YES!
Nice but racing vids on YT = :bashtard:
Zerb
Post by Zerb »
Mcstiff wrote:Nice but racing vids on YT = :bashtard:
ya, oh well. ive seen worse.
loxxrider wrote:once again,
YES!
x2
Oh for sure, I'd just hate to get busted because of YT!
mr_aj_johnson
Post by mr_aj_johnson »
:stupid: I might pull that one down. it clearly shows your face
Zerb
Post by Zerb »
ok, ill blur it out in final cut and put it back up.
Jiggle_Billy
Just put a disclaimer at the bottom about it being made in mexico on one crazy afternoon.
