Page 4 of 4
Re: Custom AAN Motronic mapping
Posted: Wed Feb 18, 2015 9:37 pm
by Marc
PRY4SNO wrote:Marc wrote:if no rods, do the EFR 6758. stock turbo spool and mid 300whp on 91 craptane.
Ohhhh that's tempting.
What's the cost difference for Motronic tuning an EFR vs. billet k26, on a UrS4?
depends. for those turbos that fall within the range of the stock MAF (the 6758 on pump gas will be) its the same price. ($500 without launch control, $550 with launch control. there will also be package discounts with purchase of turbo available)
for the higher power stuff we need speed density or big maf (rs4) which I charge $250-$350 more for depending on configuration.
Posted: Thu Feb 19, 2015 10:12 am
by hanicus
When you say stock spool do you mean k24 fast?
I do have rods, but what I really want is the fastest spooling 350+whp setup possible.
Posted: Thu Feb 19, 2015 10:22 am
by Marc
hanicus wrote:Marc wrote:if no rods, do the EFR 6758. stock turbo spool and mid 300whp on 91 craptane.
yep (note this graph is on e85, but the spool will be the same, just lower peak. expect close to 350whp on pump gas).
then this is the turbo for you.
Posted: Thu Feb 19, 2015 10:46 am
by hanicus
That curve seems so wide... does this completely blow a GT28 out of the water?
Is it possible to do an off-the-shelf tune for E85? I am running the 60lb injectors but stock fuel pump.
Posted: Thu Feb 19, 2015 12:16 pm
by Marc
absolutely. I can supply an e85 chipset, it will be one of the chips I'm calibrating while out there. same price as pump gas tune.
Posted: Thu Feb 19, 2015 2:31 pm
That is so awesome.
Posted: Thu Feb 19, 2015 4:03 pm
^^^ What he said...
This is very tempting!
Posted: Fri Feb 20, 2015 11:11 am
by stt
Any custom tunes for big turbo 3B engine yet?
Posted: Wed Mar 18, 2015 10:04 pm
by Mouse
Hi,
Will there be an equivalent standard plug in tuning package for the k24 billet turbos 'under development'?
And any information on these in terms of performance and in comparison to RS2 turbo?
Posted: Thu Jun 18, 2015 4:39 pm
by Uncle Helmut
Any update about this?
Posted: Fri Jun 19, 2015 8:00 am
by Marc
update on which part?
we have chips for aan billet rs2, billet k26, EFR 6758, EFR 7163, and both EFRs on e85. what do you need?
Posted: Fri Jun 19, 2015 8:16 am
by Peters
Marc wrote:update on which part?
I think Mouse meant the new billet K24
Posted: Fri Jun 19, 2015 8:58 am
by Marc
Peters wrote:Marc wrote:update on which part?
not yet. I know hank has at least one or two of the turbos in the wild, so the next time I'm out I will bring my calibration gear and make a file for it.
Posted: Sat Jun 20, 2015 8:59 pm
by Mouse
Any hp, torque, spool figures for the billet k24s?
And what about this revision which will be a "contender with the billet rs2"?
Posted: Tue Jun 23, 2015 9:11 am
by Uncle Helmut
Marc wrote:Peters wrote:Marc wrote:update on which part?
Please do! I am thinking of heading that route!
Posted: Thu Oct 18, 2018 11:30 pm
by inline560
Any chips available for 3b's?
