Page 4 of 28
Re: Josh's 2.5 200QT
Posted: Sat Mar 09, 2013 8:40 pm
by 2.5TYPE44
this looks a little better than when I started. I had to take the cooling fins off to make it easier to polish.
Posted: Sat Mar 09, 2013 8:42 pm
by 2.5TYPE44
random pic of motor mount and 7A oil pan side pouch.
Posted: Sun Mar 10, 2013 10:23 am
Labor of love :)
Posted: Sun Mar 10, 2013 1:30 pm
by quattro87
And I thought I had a bad case of the dreaded Audi desease........I have nothing on you two. :nuts: Looks good though!!
Posted: Sun Mar 10, 2013 4:50 pm
by glibobbo21
wow, you are insane. lol
Posted: Sun Mar 10, 2013 6:59 pm
by 2.5TYPE44
Thanks! :)
Posted: Sun Mar 10, 2013 7:13 pm
by 2.5TYPE44
I know I should post this in the ''swap meet'', but if anyone knows somebody that needs some 20 valve cylinder heads, intake manifold, exhaust manifold, or a turbo... let me know. I will almost give it away. i just want to make it worth my while to pack it up and take it somewhere to ship out. Anything I can do to help another Audi ''Nut'' keep one of these cars on the road. I also have the lower end too.
Posted: Sun Mar 10, 2013 7:19 pm
by 2.5TYPE44
I'm working on converting my door cards to the 200 Bose door cards with the ported boxes. My car originaly came with two tiny speakers in the dash and two in the rear deck. It has got to improve the sound and still keep it factory looking.
Posted: Sun Mar 10, 2013 7:34 pm
by 2.5TYPE44
Another project I am working on is cleaning up the engine bay and seeing if I can re-route some items to open up some space and take the clutter away. I have decided to do without the ABS module and that huge bracket. I also want to get rid of the hydro boost or whatever the proper term is for it. There are brake lines everywhere and I can't even stick my hand down in the hood because of all of the brake lines in the way. That will definitely get simplified. I will do a big brake kit and convert to a vacuum brake booster. I just hate hydraulic/oil leaks! :mad: I'm thinking I might add some porportioning valves mixed with small residual valves to help with the small master cylinder to keep line pressure at the pistons.
Posted: Sun Mar 10, 2013 7:43 pm
by 2.5TYPE44
You can probably tell that I like things to be cleaned up before going back in... I'm also sand blasting my sway bar and ''K frame"... I think that is what it is called... or engine craddle? Anyway... I am sandblasting them and getting them powdercoated. I don't know what color yet. I was thinking silver or red since the bay is red. I like brighter colors because it makes it easier to see under the hood and all the different components seem easier to identify and single out. I don't like everything to be one black camoflauged blurr under the hood.
Posted: Mon Mar 11, 2013 1:33 am
Josh, you are a beast! keep the pictures coming
Posted: Mon Mar 11, 2013 1:37 am
by amd is the best
MORE ON THE SAMURAI!!! I love them :)
Posted: Mon Mar 11, 2013 1:59 am
by pilihp2
On my phone right now but I need to message you about the turbo. Mine is smoking more and more. And possibly the head
Posted: Mon Mar 11, 2013 7:31 am
by 2.5TYPE44
Ok, just send me a message and I will reply with detailed pics of heads and turbo. Back in the day when it was my uncles car, he was always doing things with the waste gate and soldering some of his mad scientist stuff to the ECM... He was always bowing head gaskets. We would hit every junkyard in the houston area grabbing what we could of of them. We grabbed an extra head to experiment with porting and different valve jobs. The one in the picture with the valve cover and distributor was the last current head I was driving with. It was making great power but I had massive problems with the fuel injection and pulled everything out as you can see in the pictures. The turbo was making decent power too when I was getting fuel. I can check it for shaft play. I have been lugging these parts around for at least 5 or six years.
Posted: Mon Mar 11, 2013 7:42 am
by 2.5TYPE44
amd is the best wrote:MORE ON THE SAMURAI!!! I love them :)
I can post a couple pics to show my other toy. It is an 88 Suzuki Samurai that I bought in Colorado about ten years ago. I went wheeling in the mountains one day and got hung up on some boulders in a trail and it was "the straw that broke the camels back". From that moment, it made my mind up to go a little more extreme so I don't have to worry about that anymore. I would also get honked at by people behind me because I was going so slow over the passes in Colorado... Fixed that problem too.
Posted: Mon Mar 11, 2013 7:52 am
by 2.5TYPE44
Here some newer pics. Checking the flex and making sure nothing binds
Posted: Mon Mar 11, 2013 8:09 am
by 2.5TYPE44
It is a creature of many makes and models.
88 samurai body
Full age and I can still put the factory top on.
Chevy 4.3 fuel injected V6
700r4 automatic
Dana 300 transfer case
Advanced Adapter
Ford 9" rear housing shaved on the bottom for extra clearance, trussed for extra strength, full floating Warn hubs, Spooled, Dodge 3/4 ton discs with Monte Carlo calipers, 5:13 gears
International Scout Dana 44 front axle
Painless wiring
Optima battery which is the one I was telling you I have had for about 6 years now
38.5" Boggers
Posted: Mon Mar 11, 2013 8:14 am
by 2.5TYPE44
Forgot about the 36" Racerunner coil overs, quarter eleptical rear suspension, high clearance rear control arms, and some cheap racing seats.
Posted: Mon Mar 11, 2013 10:44 am
Hey, I don't know if you saw it or not, but I sent you a PM!
Posted: Mon Mar 11, 2013 4:49 pm
by 2.5TYPE44
Yeah, it was last week right?... I responded to you... Atleast I thought I did... I remember writing the response. Maybe it got censored :rofl: . You never got it though? Hum. Send me another short summary of it just so I can make sure it is what I am thinking it was.
Posted: Mon Mar 11, 2013 5:16 pm
Hey, yeah I just looked in my inbox again and didn't see anything. I don't think it is getting censored haha!
Posted: Mon Mar 11, 2013 5:19 pm
by 2.5TYPE44
I looked in my outbox and didn't see anything but I know I wrote it. I will send it again.
Posted: Mon Mar 11, 2013 5:47 pm
by 2.5TYPE44
Ok, I sent it twice... I couln't copy and paste so you should get about the same info in two different messages.
Posted: Tue Mar 12, 2013 5:56 am
by WOMBAT
Definitely watching this thread - cant wait to see what all that head work does!
Posted: Wed Mar 13, 2013 9:55 pm
by 2.5TYPE44
I am compiling my ''to do'' or ''wish list'' for 200. I have saved some pictures of some of the cool things that add that little touch that makes it stand out from the everyday stock 200.
First item is a rear spoiler. I am trying to decide on what spoiler. There is the super rare Tresser, The V8 DTM, and a couple I am not sure of.
What are you opinions?
