Page 26 of 28
Re: Pops' 1997 S6 2.5L Stroker - RESURRECTION BEGINS
Posted: Mon Jan 14, 2013 3:20 pm
Hey it's not even my car! I shouldn't be spending ANY time on it as per priorities and such as Mr. Kat said.
But yes, thanks for the links Ed.
Posted: Mon Jan 14, 2013 8:52 pm
Oh, and Frank... I've helped make two kids :)
Posted: Mon Jan 14, 2013 8:58 pm
by EDIGREG
priorities schmiorities :)
I kid, I kid - hope the mini-Chaloux's are doing well !
Posted: Sat Aug 10, 2013 9:43 am
So... everything is sold except the header. Kept the TiAL, turbo, QSV, and t3-qsv adapter. Hank, I think we're ready to join the 07k party :)
Posted: Sat Aug 10, 2013 3:40 pm
by glibobbo21
oh snap
Posted: Sun Aug 11, 2013 1:26 am
glibobbo21 wrote:oh snap
:metoo:
Re: Pops' 1997 S6 - 07k BLK WDW
Posted: Tue Oct 01, 2013 9:48 pm
lalala la la. Quote incoming on drop-in 07k swap from Hank... lalala la la....
Posted: Tue Oct 01, 2013 10:07 pm
by scubadave
As the glove snaps on...."You're going to feel a slight pinch"
Posted: Tue Oct 01, 2013 10:14 pm
I am on my way to the shop for the evening shift now. :)
Posted: Wed Oct 16, 2013 12:32 pm
Stuff is being sent out to hank this week. Crazy that things are actually happening with this car!
Posted: Wed Oct 16, 2013 5:12 pm
stuff?
07k in the future?
Posted: Wed Oct 16, 2013 5:18 pm
07k is happening now ;)
Posted: Wed Oct 16, 2013 5:30 pm
Sweet! Cant wait to see one in a UrS.
Are you keeping all factory accessories?
Posted: Wed Oct 16, 2013 5:36 pm
Factory 07k accessories :)
Posted: Wed Oct 16, 2013 5:43 pm
Right but A/C and power brakes/steering will function as normal?
Posted: Wed Oct 16, 2013 5:50 pm
Yes. PS will be a chore to sort, but we will get it. The easy way out is electric pump, but we will probably make a special pulley for it and put it on the serp. Stock 07k is R134 just like the s6, so no problems there.
Posted: Wed Oct 16, 2013 6:17 pm
by Marc
my vote is to convert the brakes over to vacuum. especially since the 07k has a vacuum pump anyway ;)
Posted: Wed Oct 16, 2013 6:24 pm
Yes, Left foot braking FTW!!
Posted: Wed Oct 16, 2013 6:49 pm
We even have an a6 here to pillage brake parts from.
Posted: Wed Oct 16, 2013 7:08 pm
Bam, that is easy.
Posted: Wed Oct 16, 2013 7:35 pm
Very cool :)
Guess the r-12 guys have it a bit harder, oh well I can't do it until CA relaxes its smog laws anyway.
Posted: Wed Oct 16, 2013 7:45 pm
I bet I could get an 07k running on stock motronics without too much trouble. Would lose the VVT without some crafty output reassignment, but the rest is pretty darn close to what a regular 20vt has. Not like it is OBD2 or anything.
Can't be too hard to just swap 134 stuff over to r12 right?
Posted: Wed Oct 16, 2013 7:49 pm
by highlander69
Hank,
It's easy to retrofit R12 stuff to R134 stuff. You lose a little in cooling efficiency, but it's easily doable.
Cheers,
Craig
Posted: Wed Oct 16, 2013 7:59 pm
You just have to change hoses for the most part. The r134 eats away and leaks from the r12 hoses. I guess if that is an issue an 07k swap is out of the ballpark ;)
Posted: Wed Oct 16, 2013 8:33 pm
Yes, Good point.
I'd love at some point to try a Motronic AAN. Not that a Motronic ECU is anythign special, but you could crank trigger off the flywheel, with a reference pin on our flywheel, then just convert the 07k hall sensor on the cam to read the open window. After that, it would be just getting oldschool sensors on to make the motronic happy and then manifolds to work in the bay. It would probably not be all that difficult. It would need remapped obviously for the new found affinity for air, but that's the point.
