Page 26 of 55
Re: Darin's 80tq...8 pounds of boost!!!!...
Posted: Wed Aug 29, 2012 10:05 pm
by Mcstiff
It makes sense to me, pressure differential allows the valve to open via greater pressure in the lower chamber than the spring.
Posted: Wed Aug 29, 2012 10:29 pm
It really should work either way... in the bottom-port-only case, you limit boost by adding pressure to the bottom chamber. In the top+bottom port case with valve in the top port, you limit boost by limiting pressure to the top port. The two methods just call for opposing boost controller operation/configuration (one has the valve limiting pressure/duty cycle to lower/raise boost, the other has it increasing pressure/duty cycle to limit/lower boost).
Posted: Thu Aug 30, 2012 6:28 am
Just so I have this straight, if I am going to one a 'heavy duty' N75, then I need to hook it up the way Darin has it, or will 'in line' work ok?
Posted: Thu Aug 30, 2012 6:44 am
by savagerocco
There are several ways to skin a cat. You can control boost with lower chamber only, but that doesn't counter act the force pushing on the wastegate valve surface, so eventually exhaust back pressure will open. Putting pressure on the top chamber counter acts the exhaust pressure. So, if you want high boost, the upper chamber really needs to see a boost reference. The style of waste gate solenoid also has a bearing on operation. Most valves will be normally closed and provide boost reference to the lower chamber even if no signal is given, this is for default spring control. Others are normally open and would go full boost with out a signal on the lower chamber, but wastegate spring control when not getting a signal when hooked up to the upper chamber.
Posted: Thu Aug 30, 2012 6:50 am
by death 4kqt
i use a stock audi gate, a 2.2 bar spring and bleed off the pressure from the bottom port. No line to the top port.
Posted: Thu Aug 30, 2012 7:08 am
by savagerocco
By the way Darin, glad to see that it is working. You outta drive it up here to drop off the loaner tools or drop them in the mail for me. Glad the car is driving well and better off, shifting like butter..
Posted: Thu Aug 30, 2012 7:24 am
by Audilard
Brent - the inspection is due in September. I need to drive up next week to do that, thread the shift rod for the S4 shift knob, return your tools, repair a torn CV boot, look into having only one key to turn the car on AND lock the doors and figure out wiring for the 2 plug transmission connector (I believe that is for the reverse lights).
Let me know what day is best.
Thanks,
Posted: Thu Aug 30, 2012 10:55 am
by nsimps
8 pounds at birth! Congrats!
Posted: Thu Aug 30, 2012 11:25 am
clever nick!! well done!
Posted: Thu Aug 30, 2012 12:00 pm
by savagerocco
The two pin plug is reverse lights, cv boot is doable, threading shifter, also no problem, and the IM should be ok. The laws have changed since last year, much more strict and the emission department has a webcam that they use during the test but I am sure we can get thru.
Posted: Thu Aug 30, 2012 12:03 pm
by death 4kqt
savagerocco wrote: The laws have changed since last year, much more strict and the emission department has a webcam that they use during the test but I am sure we can get thru.
feck....big brother much. that sucks.
Posted: Thu Aug 30, 2012 12:15 pm
by nsimps
ShavedQuattro wrote:clever nick!! well done!
Posted: Thu Aug 30, 2012 12:29 pm
death 4kqt wrote:[/quote]
feck....big brother much. that sucks.[/quote]
Sheeeease. Left Utah just in time!! oh wait, my URQ and truck are still registered up there...
Posted: Thu Aug 30, 2012 12:32 pm
by nsimps
Just go up to St. George, no emissions (last I heard anyway)
Posted: Thu Aug 30, 2012 1:16 pm
by Audilard
savagerocco wrote:The two pin plug is reverse lights, cv boot is doable, threading shifter, also no problem, and the IM should be ok. The laws have changed since last year, much more strict and the emission department has a webcam that they use during the test but I am sure we can get thru.
Well, I believe I still have the file that passed the last time so we'll get it good and warm and give it a whirl.
Posted: Thu Aug 30, 2012 4:01 pm
by savagerocco
I'm sure we can get it to go thru.
Re: Darin's 80tq...12 psi...
Posted: Fri Aug 31, 2012 1:17 pm
by Audilard
Just out breaking in my car at 12 psi. Carry on.
Posted: Fri Aug 31, 2012 2:06 pm
lol
Posted: Fri Aug 31, 2012 4:34 pm
Audilard wrote:Just out breaking in my car at 12 psi. Carry on.
LIKE
Posted: Fri Aug 31, 2012 10:07 pm
by nsimps
At this growth rate you'll be at 30lbs in no time!
You planning on WOW next month?
Posted: Sat Sep 01, 2012 7:13 am
by PRA4WX
nsimps wrote:You planning on WOW next month?
"World of Warcraft?!"
Re: Darin's 80tq...15 psi...
Posted: Tue Sep 04, 2012 9:31 am
by Audilard
Hit 15psi on my way in to work this morning. I should be driving the car this entire week to work, putting miles on it before next Wednesday, September 12th. Wide Open Wednesday!!
Posted: Tue Sep 04, 2012 12:08 pm
Halfway there!!
Re: Darin's 80tq...20 psi ...
Posted: Wed Sep 05, 2012 5:29 pm
by Audilard
So when I originally bought the car it came tuned at 20 psi. For the most part I ran it at 18-19. So on the way home from work it returned to 20psi and I had forgotten how fast this car is! Pulls like a freight train and sounds tremendous! That's it for now until I get on the dyno and get a proper 25psi tune on it. Wide Open Wednesday next week and I'm sure I'll have the video camera mounted!
Posted: Wed Sep 05, 2012 6:33 pm
LOL. 5 weeks till be put it on the dyno!
