Page 3 of 5
Re: Zerb's 90Q...07K motor mounts
Posted: Sat Apr 12, 2014 10:13 pm
Looks real good in there. Keep up the good work!
Posted: Sat Apr 12, 2014 10:18 pm
Yeah this is awesome. Can't wait till you're hunting liter bikes again lol
Re: Zerb's 90Q...07K Aluminum Coolant Pieces
Posted: Sun Apr 13, 2014 7:01 pm
by Zerb
so, did some work on the aluminum thermostat housing today, almost finished. just a few more tweaks to the angle of the pipe that goes to the water pump and we will be set.
Started some work on the aluminum piece that comes off the back of the head as well and goes to the upper rad inlet, that will also have a -8an port for a thermostat bypass line, as well as a threaded bung for coolant temp sensor.
Posted: Tue Apr 15, 2014 10:15 am
by highlander69
Another great build !!!!!
Looking forward to updates. :beer:
Cheers,
Craig.
Posted: Sun Apr 27, 2014 8:57 pm
by Zerb
Got some time spent with my new tig welder today. Not the ugliest welds ever, not the prettiest. Manifolds coming together. Got some of the coolant flange off the head done as well.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Re: Zerb's 90Q 07K...beginning intake manifold
Posted: Wed Jun 25, 2014 9:24 pm
by Zerb
So. Little update randomness.
Bought a nifty mitre saw. Cuts any material, and does it quite well I might add.
Made a different, stronger, intercooler mount. The more I redo, the more I can practice tig welding. So it's a win win.
Ordered a set of universal fiberglass fender flares from eBay. They will certainly fit the bill. Just not sure if I want to chop them off at the bumper lines, or cut them at the bumper lines and rivet the lower sections onto the bumpers.
Here we have a catch can design that I had bouncing around in my head for a bit and decided to design it on the computer and have my buddy jet the parts out for me. It'll take better shape in the coming days, but you'll get the jist. The rear piece will curve to the front of the can like the side plates are cut. Then 90 down. The AN fittings will be facing the front of the can, hoses will go directly over the large panel filter. And done.
Where will It be venting from to that glorious can? Well from this valve cover I also designed and had jetted by my buddy.
Fittings were placed there because as I've read and seen in my research of these 07k motors there are two ports that run down the head there and into the crank area of the block for venting purposes, so I wanted the most direct route for those passageways to breath.
designed this as well and had it jetted. still haven't made a final decision on where to put it.
Some of my aluminum welding on the new upper rad support bar I made.
And that's that. Lots more to come. Tons of nifty ideas in my noggin for this one.
posted from a computer in my pants
Re: Zerb's 90Q 07K...Valve cover, catch can, mitre saw, upda
Posted: Wed Jun 25, 2014 10:09 pm
by scubagli
Nice, i say cut at bumper.
Old and grumpy.
Posted: Thu Jun 26, 2014 8:33 pm
by Zerb
Got some more of the catch can welded up today.
Should have the baffle plate tacked in there tomorrow then I can weld the filter plate in there and finish off the top vertical section you see there with the AN fittings.
Re: Zerb's 90Q 07K...Catch Can Fab
Posted: Fri Jun 27, 2014 11:13 am
You are getting better and better at welding! This is exactly the type of stuff I want to start playing with, just need to pull the trigger on that TIG..
Keep at it, can't wait to see it run.
Posted: Fri Jun 27, 2014 11:25 am
by Zerb
I would recommend this Eastwood tig 200 after using it for a bit and having my buddy who does this as a profession use it and say it's quite nice for the price. Can't go wrong. Only shitty part was the pedal setup they have
Posted: Fri Jun 27, 2014 1:30 pm
by Afterthought
Great fab work, and I really like the old school 20v turbo letters! nice looking intake too
Posted: Fri Jun 27, 2014 10:35 pm
by my2000apb
how are you going to affix the "20v turbo" to the manifold?
Posted: Sat Jun 28, 2014 8:44 am
by Zerb
we welded little blind rivets on the underside of it, i will drill into whatever its getting mounted to and affix it that way
Posted: Sat Jun 28, 2014 7:46 pm
by Zerb
Well. Chalk this one up as the first aluminum piece I have fully successfully tig welded myself. 98 percent done. Need to put some -10 bungs on there and some mounting tabs and we are done.
Now I can get rid of the holes in my firewall.
Posted: Sat Jun 28, 2014 10:19 pm
What a wonderful setup that is, love everything in here
Posted: Sun Jun 29, 2014 4:01 pm
by Colin2750
Hood clear those AN lines?
Posted: Sun Jun 29, 2014 4:53 pm
by Zerb
Colin2750 wrote:Hood clear those AN lines?
It's close. But yes.
Posted: Mon Jun 30, 2014 8:47 pm
by Zerb
Started a little intake manifold fabrication this evening. I fucked myself pretty good when I welded that plenum up, it was one of the first things I tig welded when I was learning and needless to say I didn't clamp it down anywhere and it warped, so these runners were white the bitch to get to fit properly. I had to give up a little of the perfect fit I was after just to save my sanity. I can weld it and grind it all that I need after all.
Re: Zerb's 90Q 07K...Intake manifold fabrication
Posted: Wed Jul 02, 2014 11:55 am
Looks good. You are probably going to hate life at some point with the catch can location. The rear of the engine cover is the new tight spot in 07k install. Any cam adjustements, head pull, etc, that catch can will need to be removed.
Looks great dude.
Posted: Wed Jul 02, 2014 12:10 pm
by Zerb
catch can will be held to the firewall with 2 bolts once i weld tabs onto it and press some nut serts into the firewall. so it will be easily removable, hopefully. i thought about sticking it up in the raintray and having the can in the cabin but the top of the can protrude out of the raintray and also have a square cutout for the filter to vent, but i feel as if that may stink up the cabin
Posted: Sun Jul 06, 2014 1:32 pm
by Zerb
Plugging away
Posted: Sun Jul 06, 2014 5:20 pm
by Zerb
Bang bang
Posted: Sun Jul 13, 2014 2:23 am
by ChrisAudi80
I love watching intake manifold fabbing. Don't know if you mentioned it earlier, but what TB will you use? The funnel to the plenum looks large. 4"?
Injector bosses next?
Posted: Sun Jul 13, 2014 10:13 pm
by Zerb
Injector bosses and the 2 triangle pieces I need to finish up the plenum. 75-80mm throttle body. Then it's on to intercooler end tanks and the exhaust manifold
Posted: Tue Jul 15, 2014 4:09 pm
by my2000apb
any oilpan progress?
