Audi 90 quattro with 2.5 TDI and 6-speed, plan B
Re: B4 90 quattro with 2.5 TDI
Oh, I missed that completely sorry. I'm just trying to get rid of them... I went holset on my 5k.
Quattro Krant
Looking really good there Martin. Takes a certain level of sickness to decide to rip apart a perfectly working DD to do an engine swap in. Doesn't that baller house of yours have a cool garage? I know what you mean, I was painting my windows upstairs in my garage-sweating worse then my 30 mile bike ride I did in the morning
ralleyquattro wrote:Sorry, as I said not if I ever change the turbo it will be for a variable vane type like GT22V.
Thanks for the offer.
I give you 6 months before you decide you want to step up the turbo size.
Love the build...
Highlander
Wow Martin,
Talk about a productive day!!!!...looks great
Are you coming to the shop tonight?
Cheers,
Craig
Cheers,
Craig
- ralleyquattro
Another productive morning.
Hood is closed!
Once I cut out some of this plastic lining it will be even better!
Tried the IC on, thanks to Frank Mancini.
This is going to be fun!
Could not resist.
Hood is closed!
Could not resist.
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
91 Coupe Quattro
jcarrick
Looking good! Is that the intercooler that's so close to the turbo inlet?
- ralleyquattro
Yep, I'll have to go down with intake pipe, no way o go up.
At least it's all in the same area so piping from turbo to IC and IC to throttle will be pretty short.
For some strange reason I am way more excited about this project than I was about finishing the '84.... I guess this is something new I've never done before.
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
80qtdi
Looking really good, can that compressor housing be clocked more down and the intercooler/crossmember inlet be changed? Is the ecm original to the engine? Does it have socketed provisions for a chip set?
- ralleyquattro
No need to reclock or relocate I/C... all fits well on that front.
The ECU can be chipped, problem is that it's such an early example that not too many people make chips for them.
If I decide to chip it down the road I do have a spare computer I can ship to Europe for massaging while still having a mobile car here.
It was way too hot to work on the car today, but starting tomorrow it is supposed to back to semi livable conditions so I'll be back to do as much as I can.
The pedals are still not here, that is the only part keeping me from reassembling the interior.
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Lord_Verminaard
A lot of guys are swapping the whole ECU for a Transporter/Crafter ECU so they can run a VNT turbo.
Although...... I know of a guy that programmed a slick standalone VNT controller, needs RPM (from W-signal on Alternator) TPS and MAP sensor. Can run an N75 valve just like a factory VNT. I bought a board and I'm going to play with it some to see how it works. The controller is based off an inexpensive Arduino prototype board and the guy has the code for free.
Let me know if you want more details.
Brendan
Brendan
2005 New Beetle TDI
2002 Jetta Wagon 1.8t Tiptronic to manual swap (Wife's car and kid hauler)
1981 Scirocco S'...
1976 KZ400
1981 Scirocco S'...
1976 KZ400
- ralleyquattro
I was going to swap for the AEL (140hp) version computer/harness, but it also requires MAF, different sensors, matching pump etc. So for now I'll stay with the stock setup and chip at most.
I'll let you know when stock becomes boring.
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
80qtdi
Ah, I see. For some reason I was thinking the turbo fed into the crosspipe then into the intercooler. Looks like you have it all figured out and it looks oem too.
That's good to keep it stock for as long as possible, everyone can attest, once the power adders start it's difficult to stop. Keep up the good work.
- ralleyquattro
Look what arrived today!
TDI on the left, stock on the right.
Whoever needed the gas pedal, I just wanted to make sure I don't need any parts, all is now availble.
Here is another side by side.
And closeup of the TPS.
Installed!
And the steering column back in.
Still have to run the battery cable from the trunk via the firewall so I can't put the HVAC box back in just yet.
Also got few minor things done under the hood.
Installed!
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
- ralleyquattro
Not much happened over the weekend, busy with kids and other people's cars..
Last couple of days have been productive.
- Engine is fully wired, interior portion 95% done, just need to get the HVAC box back in.
- Power steering pump on and plumbed
- Battery box has a spot in the trunk all predrilled etc, just need to have it blasted and painted.
- Battery cables are run and ground strap in the trunk done, just waiting for the bulkhead connectors, same as technoquatro's, after that I can slap the HVAC box back in.
- Original fuel filter byppassed, what a PITA, you need to lower the tank to gain access to it.
- IC to throttle connection done
- Got the propshaft shortened (used 4kq front section which is 1" shorter).
Andrew W has been working on the bumper, his efforts can be seen here!
http://forums.quattroworld.com/9080/msgs/27243.phtml
Tomorrow I hope to have the rad in and plumbed, and H connection done for the fuel sysem so I can run the original in tank pump and reduce the pressure to 5 psi, apparantly TDIs like to have a little pressure help the diesel pump, it also makes priming the system a breeze.
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
scottmandu
80qtdi wrote:About the only V-6 TDI that is worth anything powerwise is the newer Common rail 3.0 motors. Most of the VE styles had camshaft issues and really don't make much. The I5 is an awesome engine, I also had serious contemplations with this engine when it was up for sale. I'll look forward to seeing this car to completion. Good Luck.
How close is the linkage and shifter setup compared to the 80Q? Would the RS2 stuff fit in my 80 too?
I wouldn't knock the V6, I've been talking with a German who has one tuned to over 350 ps. Yes the cams are problemsome but so are the ones on the 4 cylinder. A replacement typically fixes the cam issue.
Martin, I'm way impressed on how fast this is coming together. It's not like it is a simple project with lots of parts in any junkyard. It's looking really good and should be a great DD/commuter car. The best part is it is still an I5.
Did you gain much weight in the front with the diesel block? I know that the old Mercedes I5s were hunks or at least seemed to be.
Did you gain much weight in the front with the diesel block? I know that the old Mercedes I5s were hunks or at least seemed to be.- ralleyquattro
quattro87 wrote:Martin, I'm way impressed on how fast this is coming together. It's not like it is a simple project with lots of parts in any junkyard. It's looking really good and should be a great DD/commuter car. The best part is it is still an I5.Did you gain much weight in the front with the diesel block? I know that the old Mercedes I5s were hunks or at least seemed to be.
Thanks, that's what happens when one is unemployed with not much else to do... speaking of, I'll wrench for food..
This engine is definetly much taller than stock 2.2 I5 but that would not add too much to the standard 20vt setup, the other bulky item is the pump and bracket.
A/C delete cancells that one. I do have CQ springs just in case the I5 turns out to be much lighter than the V6 it replaces. We shall see.
Cheers
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
- ralleyquattro
BTW anyone able to buy this puppy for me... the seller refuses to deal with a Canadian :frustrated:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0687031147
I'll pay for whatever costs one may incur.
Thank you!
Thank you!
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
That's about right with the free time. Any prospects? I've always said a project needs time, money, and ambition, but trying to come up with all three at the same time is what seems difficult. I could stand to miss a few meals and sure don't seem to be able to come up with the time I need to finish projects......do you make house calls? LOL
Quattro Krant
Email sentralleyquattro wrote:BTW anyone able to buy this puppy for me... the seller refuses to deal with a Canadian :frustrated:
Thank you!
- ralleyquattro
Thank you Richard!
Another piece of the puzzle..
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Warner
Very good Martin its moving along well.
Bumper will be painted early next week.
Wow martin this came together pretty quick! Makes me hopeful for my TDI swap
Are you on TDIclub? There's a member there who does GTB turbo kits... I was thinking of eventually going for a GT1756vk... quicker spool than the VNT15 on the ALH (1900rpm) but good for 230bhp, same as a stock //S!
Either that or the 17/22 as it's a lot less work, manifold and turbo all in one. 10hp less, 100rpm more spool.
OR just get my VNT15 bored and bigger comp wheel. We'll see
- ralleyquattro
You 4 cyl guys have ton of options, unfortunately since there are only so few of these 2.5s here I will have to go to the fatherland for some go fast goodies and ECU chipping. For now stock is the word.
If anything I have had my eye on a nice GT22V from a 151hp Eurovan.
Did very little today, that kind of a day.
Martin Pajak
91 Coupe Quattro
91 Coupe Quattro
Quattro Krant
My contribution to this build will come when I give you the relay Thursday. Also, I want to RAPE Shannon in return for the relay. I'm talking bound and gagged in a french maids outfit style of raping
