1984 Ur-quattro 20vt, 336whp 380 torques, 6-speed
Highlander
Re: 1984 Ur-q with 20vt, analog or digi dash???
Post by Highlander »
ralleyquattro wrote:Well... both the '84s and the Sports, right? ;)
Yeh Sports too :woowoo: Mike also has a 20v 84 urq and is doing a Sport project.
Triplets!!!!!
Cheers,
Craig
ralleyquattro
Post by ralleyquattro »
So, bit of an update. Wife and kids went away for the weekend so I got some time to play.
It was a hectic schedule but got things done.
All wiring harnesses are in, carpets are also back in.
But, the main goal was to finish the engine assembly and install in the car.
Being a MOFW here are the pics.
Head on and tightening of the head studs.. I hear these have to be retorqued after 1000 miles?
7A cover for the retro look.. ;)
MTM manifold needed a bit of massaging to fit with with phenolic spacer, not much but enough to need a grinder.. :(
Shifter option # 1 is full RS2 setup using the A6 shifter pedestal to save from cutting the floor.
This option makes it very easy on the transmission end, but still requires a bit of tweaking on the interior side.
Shfter option #2 is 016/UrS4 inner portion, however the tranny end is a bit tricky.
She looks very comfortable there ;)
That intake is a bit close to the front clip, next step is to start getting that Intercooler in there, I think the one I got is bit too big.. we'll see
More to follow.
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
soooo coool
i say analog dash
ralleyquattro
Sorry, but the digi harness is already in.. ;)
Martin Pajak
91 Coupe Quattro
Re: 1984 Ur-q with 20vt, engine is in!
hahah ok thats cool too, did you get in touch with jim, hes got brown seatbelts and all sorts of stuff from his 84 thats going back to black
ralleyquattro
Yes, I did, thanks, those carpets are from his '84.. they were in great shape!
Martin Pajak
91 Coupe Quattro
Kuma
Post by Kuma »
Martin, that thing looks great!!
quattro87
Post by quattro87 »
:woowoo: Good job Martin. It looks like it's coming along nicely.
Nice Martin! The car is looking like it is coming together! Looks like another monster urq in the making. I will be interested in to how you deal with the 01e linkage.
white 83UrQ
Post by white 83UrQ »
Looks like a vacuum brake setup?
ralleyquattro
white 83UrQ wrote:[/quote]
Looks like a vacuum brake setup?[/quote]
Yes, I thought about keeping the hydraulic, but for simplicity sake I chose the vacuum.. plus I had all the parts handy.
If anyone needs any hydraulic parts I have like two or three complete systems now.. ;)
Martin Pajak
91 Coupe Quattro
ralleyquattro
ShavedQuattro wrote:Nice Martin! The car is looking like it is coming together! Looks like another monster urq in the making. I will be interested in to how you deal with the 01e linkage.
I think I've chosen the Ur-s4/016 path. I don't have any 01Es at the moments (all sold) and still waiting for the three to arrive from Europe so it might be a while till I have something to work with.
Then the driveshaft puzzle will commence as well.
Cheers
Martin Pajak
91 Coupe Quattro
quattro87
Post by quattro87 »
Cheers
Can't wait. :D I like puzzles!!
eventuallyblue
Post by eventuallyblue »
Gorgeous!
84urq20v
Post by 84urq20v »
Nice Martin.
Gotta say I was wondering how you were living with no urq. Must have been daily misery for you :-)
Looking forward to seeing it on the road - here and hopefully in person one of these days/months/years.
Highlander
If anyone needs any hydraulic parts I have like two or three complete systems now.. ;)[/quote]
Looks great Martin!!!!
I'm really glad you went with the vacuum brakes.....much cleaner IMO, and less weight.
I can't wait to see this thing running.
Brilliant project.
Cheers,
Craig
ralleyquattro
84urq20v wrote:Nice Martin.
It's been hard.. many sleepless nights :(
Martin Pajak
91 Coupe Quattro
Carlos
Post by Carlos »
Wow very nice!!
white 83UrQ
So how different are the MTM and the Wagner IM?
I'd consider using one of them on my build, currently have all the RS2 IM, fuel rail, pressure pipe, ect!
What radiator you planning on using, or going to angle a stock sized one to clear the AAN oil pan?
Jack
ralleyquattro
So... tried to get the intercooler in... looks like I either have to move the motor back at least a 1/4" and move the motor mount down 1/2" or just get a smaller intercooler (the easy way out). I am still refusing to cut any of the original sheetmetal!
So, pics... here it's looking good.
Not so good here, actually touching the cover.
And no way to get the snub nose stopper in.
I also do not have a proper pulley, but it looks like it might just clear.
hank, you have the same size and yet you somehow got yours in.
This IC is 28x9x2.5
I wish there was a 28x8x2.5 but the only size smaller is 28x7x2.5.
Comments, suggestions are welcome
Martin Pajak
91 Coupe Quattro
ralleyquattro
Jack[/quote]
Hi Jack,
I don't have a Wagner so can't comment on side by side.
ABY/ADU fuel rail fits the MTM no problem, 3B might but I haven't tied one yet.
I'll be using 034 alloy rad with RS2 shroud and 5kt fan.
The engine has 3B/7A oil pan so no need to tilt the rad.
HTH
Martin Pajak
91 Coupe Quattro
is that at the stock length Martin, or is it at the 01e length without a 15mm spacer? Why not ditch the spacer and get a free 5/8"?
That looks a lot like my IC, but the updated bar and plate design. I wish I was working with a serp setup like you are though. I may bite the bullet soon and re-balance the assembly with the AAN setup. Why is the 9" too tall? Does it hit the crank pulley?
1wheelpeel
Post by 1wheelpeel »
Looks great Martin!
ralleyquattro
ShavedQuattro wrote:is that at the stock length Martin, or is it at the 01e length without a 15mm spacer? Why not ditch the spacer and get a free 5/8"?
Transmission is not there yet, this is at the limit of the engine mounts, I might elongate them a bit at least 1/4".
My clutch setup is for non spacer application, so none will be in place once the tranny slipps in there (I hope).
I've decided that I'll lower the snub nose a bit which means custom design.. it will look like the sport one that's made of steel plate and a pipe. I'll try to find a pic of it.
Like Craig said, the IC will be toughest part of this project. Wish I had a tig welder and knew how to use it.. ;)
Martin Pajak
91 Coupe Quattro
glibobbo21
Post by glibobbo21 »
looking good!
