1.9 TDI into 90q: resurrection and for sale
Re: Lowest HP swap ever: TDI into 90q
why not do with Tim did and actually LOWER the subframe with extended bushings? If I remember right, Dave made him a set and might a few extras laying around. But then again, I dont know if you want aluminum bushings
Use a 1.8t sump and pick up. Also use the oil filter housing from it aswell
Foscora wrote:Hi !
Nice project here !
Worked a bit on AHU engine (for Vanagon T3 swap).
"Low range" gearbox will not be a pain as the engine will be a bit "short" on a 90Q.
Why not considering modding the engine for a TDI-M spec ?
With injection pump from 1.9TD, turbo from 1.6TD and slighty bigger injectors (can't recall the engine it's from, 110hp TDI maybe), that's 120whp+ easily gained, which is much more confortable I guess
In case you're interested, I could find the full setup
I had originally planned on doing the MTDI. I decided to keep it eTDI because I have all of the electronics to do it and I kind of like the process of wiring a swapped engine .its a fun challenge. Also the eTDI runs and starts so nice and smooth, and I think it is a step backwards to go back to a manual pump. I think its all a matter of personal preference, people argue eTDI vs mTDI all day long.
quattro wrote:Use a 1.8t sump and pick up. Also use the oil filter housing from it aswell
yes, this is the solution I have found. Use any pan and pickup from a longitudinal vw/audi 4 cylinder with the AEB cooler/filter mount. Excellent. This is why i wanted to get the engine in the bay and start finding these little details.
If you need B5 1.8t parts let me know, the yard here is full of them and stuff is usually pretty cheap. And I've got a jacket with big pockets
vt10vt wrote:If you need B5 1.8t parts let me know, the yard here is full of them and stuff is usually pretty cheap. And I've got a jacket with big pockets
Yes..yes he does. Kind of funny the things I have seen pulled out of those pockets
sort of like my tool box that perfectly fits 7a heads. The trick is carrying it in and pretending it actually weights 80 lbs when it only weighs 10.
dana wrote:I had originally planned on doing the MTDI. I decided to keep it eTDI because I have all of the electronics to do it and I kind of like the process of wiring a swapped engine .its a fun challenge. Also the eTDI runs and starts so nice and smooth, and I think it is a step backwards to go back to a manual pump. I think its all a matter of personal preference, people argue eTDI vs mTDI all day long.
Ok I see your point and I agree for the step backward, that was just curiosity
In a way I would rather see your project going eTDI in case your furthers plans are about enhancing it, because I've never seen the process behind !Re: Lowest HP swap ever: TDI into 90q
i certainly do plan to at least have the ecu tuned and use larger injectors to get to the limit of the stock turbo. I also would like to have the ecu tuned to get rid of the MAF and EGR system
Put an HX40 on it!
- themagellan
....and the smartest man of the day award goes to this man. Don't know how I forgot that I think it's the exact same thing people do with 3A's to put them in foxes... Duh
DE80q wrote:vt10vt wrote:If you need B5 1.8t parts let me know, the yard here is full of them and stuff is usually pretty cheap. And I've got a jacket with big pockets
Dana is the king of 7A junkyard heads, I can't lay claim to being the best. I'm at a disadvantage because they search your tool boxes/bags most of the time here and they're pretty good at finding things, ask me how I know
Winter is the best junkyard time for me. Gotta layer up when its cold out.
ahh yes, when i lived 5 minutes from the junkyard and could sense when a fresh 20v 90 was delivered. Yoink! two heads per trip, and pay for one. Perfect.
I want this setup in my 4kq so hard...
90 Coupe Quattro - 3b + 01e
87 4000 - future trail rig
smokey sideways action with 40+mpg. Can not wait.
trial fit #2. AEB oil pan, filter mount and starter allowed it the engine and trans to actually bolt together for the first time!
AEB starter
I am planning on making a mount that replaces this one and grabs the factory audi rubber chassis side mount
AEB oil filter mount is key
AEB oil pan
exciting bonus, a little tweaking of the audi power steering pressure line and it fits the TDI pump!!
had to twist this coil a bit to get the PS line to fit.
actually bolted in this time.
AEB starter
AEB oil pan
The aeb starter might not have enough juice. I tried using an AAN starter on my alh swap and it could barely turn over the engine. So I used a starter from a passat TDI. I think. I dunno it's in my thread in my sig
aeb starter was mostly for mockup, that one if from a flooded car, so it doesnt work anyway. I assume i will need to find a tdi starter as you say.
busted some more out today. Going to the dominican for a week, so i wanted to make some more progress before i peaced out.
i had this crappy winch plate that i took off my 4runner that i cannibalized for the plate.
high tech bolt pattern matching
measuring for back spacers
mounts completed
drivers side mount
passenger side mount, going to add some gusseting to this one.
final driveline angle. seems good, but the oil cap hits the hood. Might need to find a way to lower that.
mounts completed
drivers side mount
I have a spare known good aeb starter if you wanna try it
not too much interesting to report. Spend some time traveling in the Dominican, and that was awesome. Now I'm back to deal with all the pain-in-the-assery that is the northeast in the winter. Why did I leave the place that was 88 degrees every day, beers were $1, food was $2 and women treat American gringos like rock stars?
Oh well, back to the fun. The motor is out for the final time to be cleaned up, resealed and then hopefully installed permanently.
I decided to actually drop some coin on a real clutch that will hopefully put up with any amount of torque I can realistically get out of the TDI. We all know that keeping this thing on the stock turbo will be hard for me. I ordered up a clutchnet stage 3, which should be able to handle 375ft/lbs but is still full faced and hopefully has good manners. I really don't like how puck clutches drive.
That little oil cap extension just twisted off and the cap can be installed flat on the valve cover. Easy enough fix!
dana wrote:not too much interesting to report. Spend some time traveling in the Dominican, and that was awesome. Now I'm back to deal with all the pain-in-the-assery that is the northeast in the winter. Why did I leave the place that was 88 degrees every day, beers were $1, food was $2 and women treat American gringos like rock stars?
Probably because you're so excited to drive my 5k back to VT from Carlisle. I understand, I'd be excited too.
that's got to be the reason.
What with the large population of cougars you claim to have around your mountain I doubt that was a factor.
lol, cougars. Not much of a cougar hunter myself.
