Page 3 of 3
Re: 1995.5 URS6 EFR 7163 w/ QSV, E85 Build
Posted: Mon Jan 23, 2017 6:47 pm
Xona turbos are great, it's a pretty even match up really. They are more compact, but they also don't come with the extra goodies the EFR does.
Hank runs the Xonas on his TT-RS kits like the IMS1000 and IMS850. If you have not heard of these, just do a little searching on those
Posted: Mon Feb 20, 2017 1:24 pm
by Herbehop
Have any pics of your air filter setup you'd be willing to share?
Thanks a bunch!
Posted: Mon Feb 20, 2017 3:29 pm
by 955urs6
Here are some photos of the air intake. Front of air intake touches front of right front fender well, goes up towards turbo and hooks around to front of turbo. Apologize for bad photos but using a manual focus Leica in one hand and flashlight in the other in a dark garage proved to be a challenge. Hope this helps!
Well, I give up, Imgur won't work right now.
Posted: Mon Feb 20, 2017 4:51 pm
by Herbehop
Thanks for trying! Did you try to just put the link?
Posted: Wed Feb 22, 2017 8:36 am
by 955urs6
Imgur won't upload anything, unfortunately.
Re: 1995.5 urS6 EFR 7163- New Parts and Flywheel PSA
Posted: Mon Mar 27, 2017 9:35 am
by 955urs6
Just replaced these parts through Marc after removing trans:
Trans mounts
https://store.034motorsport.com/transmi ... 00-a6.html034 Performance Snubnose mounts (there wasn't one installed at all !?!)
https://store.034motorsport.com/snub-mo ... thers.htmlClutch kit is in (7A style southbend stage 4 extreme, sachs 707pp and fidanza lightweight flywheel)
Turns out I didn't even have a lightweight flywheel yet, I can't wait to feel the response now that we've lightened er' up.
PSA: 7A style flywheels are thinner than AAN and don't use an AAN style pilot bearing. They use their own, larger diameter that goes in with two circlips.
Flywheel from Fidanza didn't come with a pilot bearing and had to be ordered.
7A style on the left, AAN on the right
@herbehop, here are the pictures of the air filter location. It buts up against the front of the right front fender well and 180s to the turbo.
Posted: Mon Apr 10, 2017 3:48 pm
by 955urs6
Posted: Tue Apr 11, 2017 12:27 pm
What's the canister with the pressure switches hanging off of it? Car looks great BTW
Posted: Tue Apr 11, 2017 3:17 pm
by Marc
audifreakjim wrote:What's the canister with the pressure switches hanging off of it? Car looks great BTW
we have his spool valve controlling on EMBP.
Posted: Tue Apr 11, 2017 5:37 pm
So is the canister designed to keep the crap out of the switches and prolong their life? Tell more
Posted: Tue Apr 11, 2017 5:56 pm
by Marc
audifreakjim wrote:So is the canister designed to keep the crap out of the switches and prolong their life? Tell more
you'll see the little stainless tube running off the #5 runner in his photo. that runs to the canister at the top. there is another port on the canister that is an adjustable pressure switch (we have it set around 12 psi as I recall). that switch runs to a standard 3 port MAC style valve that uses regular intake mainfold pressure to swing open his QSV. there is a second pressure switch on the canister that is set as a warning, pressure on that is around 35psi which lights up his CEL. there is a drain on the bottom of the canister in case it fills up with water (in our testing, it self evaporates so doesn't really need emptying). the VEMS is also t'd into the actuation pressure switch, I have it set to automatically open the valve over 5000 rpm as a failsafe. the port locations are setup to force the moisture to swirl to the bottom of the canister and not damage the switches.
all seems to work very well. pretty happy with how it turned out.
Posted: Wed Apr 12, 2017 7:59 am
by dana
Marc, your electronic/automotive nerdery is fantastic. What a great idea, and cool to see it implemented.
Posted: Wed Apr 12, 2017 11:13 am
Marc wrote:audifreakjim wrote:So is the canister designed to keep the crap out of the switches and prolong their life? Tell more
I love it, pretty much what I have been wanting to do with my setup.
Re: 1995.5 URS6 EFR 7163 w/ QSV, E85 Track Update
Posted: Wed May 03, 2017 8:21 am
by 955urs6
Well,
I finally took the S6 to the track. What an experience. First, I'm putting Toyo R888 on next time. I was at Grattan in Belding, MI, a fairly small track for this kind of car. The car performed flawlessly other than I cracked my right front rotor (as I got home from the weekend 2 hours north! lucky.) The guys there were all very impressed at Hank and Marc's craftsmanship and engineering. I had no problems with the car other than I had to empty the canister the pressure switches are attached to.
The Torsen Rear Diff I put in really put the power down, I had no issues getting out of corners. The second day in the rain (it was pouring) I was one of the fastest cars out there because now, I had the right tires. I didn't even really have to change my line that much when everyone else had to avoid the sealant and take a rain line.
In modifications, all that is left is the front rotors, and we think that power steering pump may be bad because my brake light keeps going on and we know it isn't the accumulator (brake bomb). The power steering pump also supplies pressure for the braking system so that could be the culprit.
Here are a couple pictures from the weekend. Such a great experience- I kept up with a 500hp B8.5 S4 on R compounds, at least on the straight. Almost time to turn up the boost to 35psi! On a side note, how do I edit the title of my project rather than just the post?
Posted: Wed May 03, 2017 7:29 pm
by Grillage
Looks great! To edit the title, go back to the first post and change the title there.
Posted: Wed May 03, 2017 9:33 pm
Hot damn, how did I miss the EMBP setup posts. Thanks for that info Marc, that's exactly the setup we want for dad's 07k. Pulling it off of one of the runners is better than the collector? I guess it should read the same...
And nice work at the track, Cameron. These cars are heavy as balls but it's still fun going to the track to mess around. Did you/Marc ever dyno this car in the end?
Re: 1995.5 URS6 EFR 7163 w/ QSV, E85 DYNO SHEETS
Posted: Thu May 04, 2017 7:51 am
by 955urs6
Matt,
It was a blast at the track. I had Cooper Zeon RS3-As on which are an all season leaning summer tire- it was not ideal in the dry, so Toyo R888s for next year. In the wet, they were awesome- I was still able to his 125 on the straight and not hydroplane like everyone else... I've attached the final dyno sheets, the car is currently detuned because I havn't redone the tune since then new clutch. Marc tuned it for the stage 1 clutch that was in the car at the time so it could hold it. 420whp on E85 and 360whp on pump, 26psi and 24 psi, respectively. In 2 weeks Marc is remote tuning it up to 35psi! I'll eventually get to a dyno downstate but am in no hurry.
Not sure why the boost says it comes on so late on the dyno, but on the street it is around 3500.
Posted: Thu May 18, 2017 10:12 am
Awesome! Some good numbers!
Posted: Thu May 18, 2017 11:10 am
by mushasho
955urs6 wrote:Matt,
1000 rpm sooner on the street?
Posted: Thu May 18, 2017 4:00 pm
by 955urs6
Good numbers, but wait until we add 10-12 lbs of boost! @mushasho, yes, the load on the street is different so spool is much sooner. It normally isn't 1000 rpm, but anecdotally yeah, boost hits closer to 3500 than 4000 for me on the street. I'll eventually re-dyno it when we turn everything up to 35psi.
Posted: Thu May 18, 2017 4:14 pm
by mushasho
955urs6 wrote:Good numbers, but wait until we add 10-12 lbs of boost! @mushasho, yes, the load on the street is different so spool is much sooner. It normally isn't 1000 rpm, but anecdotally yeah, boost hits closer to 3500 than 4000 for me on the street. I'll eventually re-dyno it when we turn everything up to 35psi.
Please invite me,... We could schedule dyno time on the same day...
Sent from my HTC 10 using Tapatalk
Posted: Fri May 19, 2017 11:20 am
by A1QSHIP
955urs6 wrote:Well,
What I've been saying! EDL & Torsen FTW!
Posted: Mon Oct 30, 2017 9:11 am
by 955urs6
Well, it has been an interesting summer with the S6. When I took it to the track, the front rotors cracked. I was able to track down the original builder of the car in 2000 to find what the rotors were on the car, they are custom 2 piece rotors made for the Porsche 993TT calipers. The company that made them, Coleman Racing, is still in business and had the blueprints! We just had to redesign the hats because they cracked at every bolt hole on the flange. This took a lot of back and forth in design but we settled on a beefier hat that won't crack!
After I got the brakes fixed, I was able to turn up the boost to about 34psi and it, obviously, rips. Hank/Mark say that should be 500whp+, but I havn't gone to a dyno. Well, after that power level for a couple hundred miles, the radiator and brake lines started leaking so now those are being fixed, which brings me to my question-
What is the best radiator for these cars? I need to buy a new one. OEM/Aftermarket?
Re: 1995.5 URS6 EFR 7163 w/ QSV, Need Radiator Suggestions
Posted: Mon Oct 30, 2017 11:46 am
I have seen some beautiful custom ones from Europe on the S2 forum but can’t speak to the quality or fit. I have a Nissens and it has worked without issue for me. I run Evans NPG coolant with a vented cap so there is very little cooling system pressure to blow the end tanks off the radiator like I have seen happen to others. A NOS radiator would be great but if Audi had them made recently the quality will be less than it was in the 90s.
Re: 1995.5 URS6 EFR 7163 w/ QSV - FOR SALE
Posted: Thu Jun 18, 2020 11:46 am
by 955urs6
All, I never thought this day would come, but I have decided to sell my beloved ur-S6. I would like to sell it on here to someone who will respect and use it as I have, with lots of love and throttle.
I am asking 39000 OBO, you can see the build on here.
I am buying a house and unfortunately could use the funds for a down payment, I wish I didn't have to sell by my loss is one of your gains.
My number is 231.499.2552, please call me if you have any questions, call Marc at EFI express at 603.413.6713 or Hank Iroz, they all have their hands in the build.
Thank you all for the time and I look forward to posting a sport quattro on here some day...
Cameron
